I've done some searching on this site and google etc, Im still stressing because i believed my engine to be a series 1 RB25det (as it has the ignitor ontop of cam cover) BUT today i bought an oil filter from a workshop, he gave me the wrong filter & upon returning i asked for the same filter currently on my car (Z442) the guy said they are for 1998+ RB25DET's only..
I've already bought cams for a series 1 RB25 yet to be fitted.
can anyone confirm this?
the wrong oil filter could have been put on at any time in the past.....z224 is a straight replacement that is a little smaller so maybe a mechanic just used it because thats what they had on the shelf, or maybe like me they had to change to that when something like an oil fitler sandwich plate was installed.
however I am pretty certain Z224 is not correct, factory fitment on any skyline including post 1998. They are off ca18 silvia, micra etc.
Thats great info guys, I appreciate it.
I have no AFM (Microtech ecu).
The guy pulled out his booklet and claimed Z442 filters are for 1998+ Rb25dets.. so the last of the R33's then R34s.
I'm hoping (as Duncan suggests) that its just the wrong filter currently on as the last filter change was done by a workshop.
I'll do an oil filter change this week, see how it goes with the Z442, might clear some things up
Forget the oil filter that's on there, any monkey could have grabbed a random one that threaded on and used it. I don't remember seeing a Z442 in the reference book, I have a series 2 and it definitely uses a Z145A filter.
I run a Z145A on my S2 motor however its not post 1998. interesting how the guy said it was for late models?
1998 was the last year of the R33.
http://www.noelsautoparts.com.au/FILTER%20CATALOGUE.pdf
This book lists RB25DET in two date ranges, 91-98 and 98-on. 91-98 is the R33 and uses a Z145A filter, 98 on is the R34 and uses a Z442 filter. The Z442 will be no good on your R33, the thread will be wrong.
Just to clarify that, Z224 has the right thread for all RBs, it is just physically smaller.
So it won't stuff anything, but the bigger the filter for the available space, the better
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
