pretty stock??? i dont think 300kw is stock! lol
Very nice ride tho!!!
so maybe i lied. :ermm:
Forged RB25DET Conversion
Polished and ported head
RB25 gearbox with short shift kit
Tomei technical trax 2way diff
FMIC and piping
KKR480 Turbo (will likely get a GT3076R soonish)
Koni adjustable sports suspension
R33 4 pot front calipers with 325mm slotted rotors
R33 2 pot rear calipers with 300mm slotted rotors
Power FC + hand controller
Shift light
HKS super squeaky (coming off asap)
PWR alloy radiator
Twin bucket seats
Sparco hyper fang II 17x9" all round
3" turbo back exhaust
Z32 AFM
720cc nismo injectors
700hp fuel pump
Gates timing belt
only popped one box in the leggy.. the second box is still going strong after 30+ launches and lots of tiptronic shifting... first one was obviously just a dud.
had the leggy for over a year now, i wanted more power, and its not worth spending $3k just to convert it to manual, then stupid amounts to be the first person to upgrade turbo's, etc...
might as well come back to something that is tried and proven, and i know skylines and RB's like the back of my hand.
and yes kark, you'll be familiar with 31 tail lights. :sick:
pits shouldn't be an issue.. as far as they are concerned, its a "stock" RB25, and has R33 brakes with bigger than 33 rotors on it, and upgraded suspension.. should pass easy.
i dont like people who derail trains between me and my car. :laugh:
it's sitting loaded on a train in adelaide waiting to head to perth...
fortunately it got to adelaide BEFORE the derailment, so it's on the first train to leave hopefully on monday.. anything that arrived after is backed up big time.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
