Shame the weekend finished this way for us- we were running 8th outright at the end of the first day - not bad for Pete's first steer in the car.
Sadly, it looks like just a case of crap road surface (gravel, melted tar and oil don't mix) coming out of the corner, putting an end to an otherwise good run.
I think Pete's driving is the only reason we didn't roll- he managed to wipe some of the speed off and hold the car balanced as we slid 12ft down the bank!
Actually Liz, alot of the farmers who raced up to see the damage thought i had been driving - I ofcourse told them I would have caught it if that were the case >_<
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4403607
went out and saw the car today. not a massive amount of damage just the just the coolers radiator etc were pretty messed up and also a heaps of the guards. transplanted what needed to be transplanted from the half cut (also there) and it should be good. other than that all the 4 wheels were bent and some other little under car stuff i think
pete said the main amount of damage to the coolers etc happend at the bottom when it hit the ditch..also said he was very lucky that he didn't hit any trees and what not.
and also said kel was very very calm and seemed to care more about pete than the car :laugh:
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4413447
My middle name is calm :(
Pete did a great job to slow the car down and then keep it together as we headed down the bank- i keep saying this but i still have no idea how we didn't roll.
He's a bloody good driver, and it's such a shame this happened because he was on track for a pretty good result for his first time in the car.
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4413475
  • 3 weeks later...
There really wasn't that much damage to see - the front bar was barely marked, just hanging a bit loose. There was some panel damage to the front quarter panel from memory from hitting something solid on the slide down the bank, but again nothing too look at.
By all accounts Pete has almost got the car back to brand new and definitely ready for Targa in a few weeks.
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4443132
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
