Hey guys,
A friend of friend wants a PC built - Now othen two packaged machines from CPL, I have a custom built option
here is my configuration:
Intel Core 2 Quad Q8200 (2.33GHz/45nm/1333FSB/4MB)
ASUS P5QC Systemboard
Corsair 4GB DDR3 1333C9DHX or Kingston 4GB 8500C5 Twin HyperX (DDR2 1066MHz)
Seagate 1TB SATA2 HDD
Powercolor 1GB HD4670
2x Pioneer DVR-216D SATA DVD-RW Drive
Logitech Cordless Desktop 1500 Rechargeable Keyboard + Mouse
22” Samsung 2233BW LCD
Foxconn TLA-889 Case
Coolermaster Extreme 650w PSU
Altec Lansing FX5051 5.1 Speakers
I'm guessing that he wants an all-around PC..I'm also trying to "future proof" him for a while (yeah I know the Intel i7 has hit the market but there are way too expensive)
what do you guys think of this setup and should I get him to go with DDR2 or DDR3 (the price difference is $76 ($215 for DDR3 and 139 for DDR2)
thanks in advance
https://www.sau.com.au/forums/topic/255244-new-pc-build/
I should have gone window shopping in the forum first...silly me
budget - he hasn't give me an exact price (I hate when people don't give me one)...I'm guessing he wants a machine for the internet, and with a bit of gaming
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4403206
Tell him he needs to decide on budget
Thats the key thing, and when building a PC its easy to stick to the budget as there is a zillion parts to fit the bill.
Its not like a modified skyline where budget often goes out the window :blush:
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4403218
IMHO, I think PC building can be like a modifed skyline where the budget can go out the window...if that was the case then you would have a PC like PC Powerplay's The Beast...Really quick, really beautiful...but did you have to get two 30" LCD Screens and the Optimus Maximus keyboard??
I'll show my firend what his options are (one machine is $1500 another is $1600 - different CPU is the difference and then my custom build) and see what the budget is...I've asked him already for a budget and didn't give me a straight answer so I told him that if he didn't give me a solid budget to work with then i'll quote him for 4-5k machine...hehehe
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4403300
FYI: in recent weeks the Seagate Barracuda 7200.11 series and primarily the 1TB (and to a lesser extent the 500/750Gb) drives have been failing at an alarming rate (ie. permanent lock-ups when booting) due to faulty firmware codes. But, don't fret Seagate has released a firmware update to rectify the problem, however, my SG 7200.11 500Gb drive of 7 months is still running fine.
If you want a better alternative and IMO currently one of the best performing $ p/Gb HDD is the Samsung Spinpoint 750Gb F1 DT/ 1Tb FDT.
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4403734
the 500/750's were only killed if you used the interim fireware that was released to fix the 1TB HDD problem.
So if you didnt touch the 500/750's you'd be A-OK, but as the firmware worked on all... people updated hehe.
But ye, 1TB are not good value $ vs Gb at the moment
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4403873
Hey guys,
22" Samsung 2233BW LCD
thanks in advance
Just a suggestion - Best he get two 500GB drives or any other 2 HDD combination - Reason being - He can physically keep his data on another drive in the event the hard drive physically crashes (partitioning a 1TB drive will only ensure the safety of data if Windows decides to go belly up).
Or if he decides to just have outright performance he can always have a RAID 0 configuration.
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4404183
The only reason I go for ASUS motherboards is that I had gigabyte boards before and built for mates and about 80% of them have failed within 2 years. My last 2 PC's had ASUS boards and never failed me
I'm going to go for 2 500GB drives for my friends setup...for what he needs - 2 500gbs are sufficient
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4410438
hey man, alright looking build but if he wants to future proof it:
Mobo - go for a P5Q Pr, not the standard one($50 more with loads of extra features)
CPU - skip the Q8200 and for a E7200 with custom cooler(still save him about $150) then overclock it to round 3.8-4ghz, quad cores are pretty poo at the moment, since nothing utilizes them and nothing will for a few year, apart from a few select games and some Adobe Photoshop products(CS4 does i believe)
Video - With the money saved by going E7200, get a 4850(extra $100) but has a lot more kick, graphics cards are more important than CPUs in most respects these days, since CPUs have hit a limit(apart from the new iCore 7s and Phenom IIs displaying some nice overclocking)
RAM - Just go with 4GB of DDR2, there isn't much a performance difference between DDR3 at the moment, just make sure you run XP 64bit or Vista 64, otherwise he'll only ever use 3.5gb
Plus 2GB chips are so cheap, fill up just two slots and have two leftover
HDD - Skip the 1TB HDD, and buy 3x 500gb HDDs for the same price, then take the first and put the OS on it
take the second two and RAID them in a striped config(RAID 0?) so it equals 1TB, this will increase performance by about 20% on the HDDs
Also they are right about the Barracudas failing, we've had several fail at work, get Western Digital, they are also quieter :)
DVD-RW - Just get teh cheapest one you can find at the time, should only be about $32 with SATA, BenQ are all good with lightscribe too
Keyboard/Mouse - You could go the logitech Desktop 1500, it's one of the cheapest laser models, I've got one here, or you could fork out an extra $30 for a Logitech MX3200 which I also have, great layout and excellent keyboard
Monitor - your choice of 22” Samsung 2233BW LCD, another good brand is the AOC 22.1" if you get it, it uses the same LCD panel as the sharp, but I guess the bezel surround isn't as sexy
Foxconn TLA-889 Case - hmmm, quite a fugly case to be honest, and cheaply made, for about $20 more you should be able to pickup a named brand like a Thermaltake/Antec/Chenbro or for 40-50 more Silverstone/Lian Li etc
PSU - Skip the coolermaster, find a Silverstone 700w modular for the same price, highly efficient and very sexy like most silverstone stuff
Speakers - Altec Lansing FX5051 5.1 Speakers - you don't need these, they are $50more than similar Altec Lansing speakers(GT5051R) and Creative/Logitech speakers with less power, only because they can be run off a USB port, they are for a non dedicated 5.1 setup, since the board above has 8 channel surround, all other 5.1 setups will plus in + 7.1 setups
P5Q vs P5Q Pro = +$40
Q8600 vs E7200+Cooler = $-100
4680 vs 4850 = $+132
DDR3 4GB vs DDR2 4GB = $-88
1TB vs 3x 500GB = $+64
Desktop 1500 vs MX3200 or Wave = $+30
Samsung vs AOC = $-67
Foxconn vs Thermaltake = $20
Coolermaster 650w vs Silverstone 700w = $+10
Altec Lansing FX5051 vs Altec Lansing GT5051R = -40
= $1 difference in NZD prices of course
for a faster system overall, better suited to a casual gamer/the internet
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4411061
Well at this stage my friend hasn't gotten back to me on what he wants to do or spend?? I have made some changes to the custom setup such as cutting back on the speakers and improving on others (from a Q8200 to a Q9550, from a Foxconn case to a Coolermaster Centurion V case)..it's just a wait and see
well i can always give him this setup:
Intel Core 2 Quad Q9650 (3.00GHz/45nm/1333FSB/12MB L2)
ASUS P5Q3 Deluxe/WiFi @n Systemboard
Corsair 4GB DDR3 1600C9DHX
4x WD VelociRaptor 300GB SATA2 Drives
2x Sapphire 1GB HD4870
LG GGW-H20L Super Multi Drive (CD/DVD Reader & Burner. Blu-Ray/HD-DVD Reader/Burner)
Logitech Cordless Desktop MX5500 Revolution Keyboard + Mouse
24” ASUS VW246H Monitor
Sound Blaster X-Fi Elite Pro
Coolermaster HAF932 Case
Coolermaster RealPower Modular 1000w PSU
Logitech Z-5500 5.1 Speakers
But with a price tag of about 6.5k - I don't think he'll go for it :domokun:
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4412142
Seriously though if he isnt gonna be doing eny enconding and so on... Dual core EXXXX.
Dont even have to get a E8400/E8500... Just a 7300 or something.
Then put a quad in there around Q3 2009 when the next price shift will come and quads will be piss cheap and overall should be a good 300 saving.
Im assuming anything will be an upgrade so the 7300 will be markedly better, they clock nice too on stock voltages :domokun:
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4412258
Personally I don't see the point going DDR3 on a S775 mobo. If you're going to go Core 2 then you might as well save some more dough (considering it kind of superseded already) and go superseded memory. Also a Q9550 won't have any trouble clocking well and trly past the 3GHz of a Q9650 without even overvolting Vcore......
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4413656
I got my mates PC built over the weekend (yes I spent Valentine's Day building the PC) here is what I got
Intel Core 2 Quad Q8200 (2.33GHz/45nm/1333FSB/4MB L2)
ASUS P5QL-E MB
2GB Corsair 8500C5D Twinx (DDR2 1066MHz)
500GB WD SATAII
LG GCG-H20L Super Multi Drive (Blu-Ray/HD-DVD Combo Drive)
22” BenQ E2200HD LCD
Coolermaster Elite 333 Case
Coolermaster Extreme 600W PSU
All up was $1660 (inc. Logitech X530 speakers, Epsom TX200 Printer and HDMI Cable)...Machine is running very nice and slightly overclocked (2.8GHz)...The Blu-Ray Drive is nice and the picture quality from the BenQ screen in 1080p is crisp. I just gotta go back and change some of the screen settings at it was 3am and had work.
The one thing that was very surpising is that the video card has no aux power connecters...which reminds me of AGP card days
https://www.sau.com.au/forums/topic/255244-new-pc-build/#findComment-4430421
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
