Hi as the topic states i have an rb30 block and crank sitting at my work and when i was pulling the block apart a found that the first counterweight has a hole in it where the balancing holes are. I was wondering if this would be repairable of look for another crank as a hole motor out here is over $300. Mr dirt? Any help or susgestions would be great and appreciated.
https://www.sau.com.au/forums/topic/255450-crankshaft-reusable/
looks like a casting flaw...get it crack tested and balanced and if its ok re-use it...its only going into a forklift isn't it?
if its a street engine it will be ok if the testing says its fine.
Edited by DiRTgarage
what about all those marks on the end is that a bearing surface
it is not unusual to see this on 30 cranks . the factory balance hole has gone through the casting. be nice to use another crank just in case the metal comes off in the engine...we have them ready to go collar fitted, micropolished ,cracktested, oil holes tapped and plugged, cleaned to go $699. www.lewisengines.com.au
quite funny that... you must really hate sau if your goin to charge the guy $100 more than advertised price on your website.
oh. and the "specials" rolling up with the crank collar $125 and the part listed for $100... anyway...
haha you have more energy than me tonight.. i read one part section and couldnt be bothered goin any further.
Edited by Cartman
thanks for pulling me up on that guys. its taken me 2 years to do that site all myself, at the beginning had no computer skills. tryin to run the site, ebay store and workshop by myself is my excuse for a few mis haps. cheers...........
Do any of you know how hard it is to proof read your own work? You can put so much time and effort into putting together a website and overlook silly little mistakes that anyone else is going to pick up first time they read it!
Give the guy a break and Darren get someone else to proof read your site and go over you current prices :)
I'd be more concerned about the fairly hefty oil pump seal (front seal) wear groove and the chunks out of the seal journal. is that damage local to that one area? it looks like the crank's been badly stored or handled and has gotten chipped by bashing into other solid objects. If you run it I'd be sure the marks on the front edge of the oil seal journal are polished out on a lathe or crank grinder to stop them tearing the seal lips, plus I'd add a bit of spring tension on the pump seal to accommodate the wear groove.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
