mate, if no ones got picks of a car painted in candy apple red check out a few hot-rod sites....the colour was THE colour to paint your rod in a while ago so I'm sure there are heaps of examples.......I know for a fact that 'House of Kolor' do a sweet candy apple red....maybe contact them for pics or samples.
https://www.sau.com.au/forums/topic/25547-car-colour/#findComment-542709
yea they are both candy apple red just under different lights and from different angles
i think the wine red with gold pearl would look good just gotta be careful that they dont put too much pearl
but the candy apple is the better of the two IMO
https://www.sau.com.au/forums/topic/25547-car-colour/#findComment-543673
what do u guys recon of the wine red color of a r32 gtst with a gold pearl in the clear coat? :
Sounds friggin good... red cars are awesome.
Jet's is pretty much the same as mine - the AN0 marone.. under certain light it can look more red, but its not a proper red. They grab attention though when tricked out with a few visual mods.
I saw an "insect" R33 around (mainly green, but touches of purple and things in there).. looked hot as..
https://www.sau.com.au/forums/topic/25547-car-colour/#findComment-543689
Hey guys,
I had my R31 Skyline re-sprayed 6 months ago..
I had the standard beacon Red re-sprayed in 2-pac with Crazy amounts of GOLD pearls thorugh it, all using Spies Hecker.
check this pic out and tell me what you think of the look..
in pure daylight with NO clouds in the sky, it changes from Deep Red to almost a HSV TigerMICA Orange/Gold
https://www.sau.com.au/forums/topic/25547-car-colour/#findComment-544180
Hey guys,
https://www.sau.com.au/forums/topic/25547-car-colour/#findComment-544181
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
