hi guys,
im personally not into fog lights being used as indicators , seems abit early 90s to me that is....
so ive re-wired my front side lights (first stage low beam i think their refered to as)
now i just need to figure out what the wattage difference is as they seem to blink fast now , im guessing due to the light not being the right wattage?? i could be wrong.
https://www.sau.com.au/forums/topic/255505-using-r33-side-lights-as-indicators/
  • 3 weeks later...
lol these fools waste there time saying search this when they could just link or answer the question in the same time spent..
anyways a mates having the same problem blinkers flashing fast and wouldnt mind it fixed...
Or maybe search "indicator" and you will find your answer, i would not have a clue how to insert a link so if someone says search something and gives you a reference use it. Don't be a nob.
search pulled up nothing mate and who has time to go threw 50 topics with the word indicator in them..obviously if the person says search he or she knows were the answer lies so why not just post it up...
instead of being "a nob"
inserting a link is as easy as cutting it from the url bar in your browser and pasting it in your reply..
Edited by thizzle
im sure the fast blinking is caused by the relay seing incorrect wattage consumption, the question is, what is the correct wattage consumption for each bulb... i think it may be easier to call repco and pretend ur buying bulbs for your skyline (rather then trying to find the answer on here as seen above)
  • 3 weeks later...
you can wire in resisters or another set of globes in line, hidden in the car to fix the correct watt level.
I can't remember which way I went as I did this mod in 2002 or 2003. fixed my fast blinking problem for my parker light indercator swap!
Edited by nizmokid
i tried resistors and had no luck...
as for tutorial....
- get indicator wires - cut
- get parker wires - cut
- thread indicator wires through to parker wire place
- splice indicator wires onto parker globes and insulate
- put in 21w globes with orange sleeves/dye
- done
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
