  • Replies 79
HEY DUDE WONDERING IF U STILL GOT THAT STANDARD AIR BOX AND SNORKEL ALSO CHASING STD STEERING WHEEL THANKS
NEED IT FOR MY CAR GOING THROUGH VIV
JUST JOINED AND DONT KNOW HOE TO DO THE PM THING CAN U PLEASE CALL ON 0408 177 146 CALL NOW IF POSS
CHEERS GRAEME
Hi, is the stock airbox and snorkel still available?
If so, can you sms me on 0412 9539589 and i'll contact you to organise payment and delivery?
Thanks!
Tams
  • 3 weeks later...
im looking for the bracket that connects onto the hub (where the 2 brake lines go into and the sway bar linkage goes into) passenger side
please pm me
thanks,
  • 4 months later...
hi mate im interested in fmic does it come with all piping? also im after the top radiator supports(there is one on either side of radiator they have a round end with rubber grommet that goes over the radiator prong and a square end that bolts to the car) also how much to post to nsw 2307 thx
