Hey Guys,
I've got an R34 that came factory with D2R Xenon bulbs.
At compliance they were removed (including ballast) and coverted to H1 55W bulbs.
I'd like to try one of those low cost HID kits from China and Xenon it up again once more.
From what I've gathered reading around various threads, I've already worked out that:
  • I want the 35W ones are plenty (that's what they are stock, no need to go for 55W).
  • I should get 4300K - 5000K ones, as I want the brightest white I can get without any blue to the naked eye.
My question is, should I get a D2R HID Kit or a H1 kit? Would it be better to remove whatever adatper or whatever that coverts the D2R socket to fit a H1?
I'm also interested in what is a good cheapie brand. I know a guy who's been using a 'Conquer' brand set from hidworld.com for 6 months with no problems at around $130 delivered.
Haxorz.
I just noticed this on another thread...
"The Xenon reflectors are designed for a D2R globe light pattern ONLY. In other words, an H1 Xenon globe will produce some glare and will not have the same quality as a D2R globe even though both will be HID lighting. "
Hmmm.... I wonder what I have to do to fit a D2R globe...
i bought D2R HID kit (came with bulb & ballast only cause the seller told me that i can use the standard wiring but mine was cut and removed during compliancing) couldn't get it to work so i sold the D2R bulbs, put in H1 HID kit, had to bend the clip that holds the bulbs down and fit perfectly.
Adapters help you to mount the bulbs easily because of the lamp base. It should look like this and should come with the kit (a pair). they allow connection of OEM specification D2R, D2S & D2C bulbs to aftermarket HV Ballast units.
http://www.alibaba.com/product-gs/20251435...xenon_bulb.html
Everytime i order BOSCH kit i make sure i get the adapters as well.
Dori34 should have got adapters with the kit to avoid bending the clips to mount the bulb. Most D2R kits come with adapters. if you need a kit let me know. It's $200 for BOSCH D2R kit pick up from Syd or $220 delivered in Australia.
Edited by R34NOS
Hey champ, narh i didnt get them with my kit, i only got 2x bulbs & 2x ballasts, i had to pay extra for the adapters. I just ditched that, bought replacement H1 bulbs, fitted it up with no dramas :thumbsup:
i thought all you have to do it take the H1 base plate out that they put in there, and you're good to go back to D2R? (provided you have ballasts, etc...)
+1 on this, really want to revert back to the D2R globes as its ment for the head lights
it depends how it was done during compliancing. mine was dodgely done, they removed the base, put in a wash modified to take a H1 bulb.
i removed both washers on each headlight but only 1 can take a D2R bulb, the other had the ballast chopped off and rewired & when i put the D2R bulb in, the hole is too big and it doesnt sit there.
how hacked does this look? you can see the H1 base plate in there, i was just under the impression i'd take it out and the D2R bulbs would sit nicely?
how are these base plates usually put in? glued? or will it just pop out? Will i have to oven the headlight to open it up?
  • 1 month later...
Hey guys im a lil lost on all the bulb stuff here.
Does anyone have a pic of what it looks like with a hid kit in it or before compliance an another pic of what it does look like when it has been compliced?
An what part is the ballast lol,
Cheers
I wanna know the answer to this question too. Can anyone help out on this?
  • 4 weeks later...
Hey Guys,
Just installed a D2R HID kit into my BNR34 on the w/kend.
In the process of doing a DIY (Didnt realise how painful DIY's are LOL) but hoping it helps clear up a few
questions that I myself had when I took the plunge.
Ben
  • 3 weeks later...
Hey guys I just got a H1 5000k kit for my R34GTT, they are f'ing amazing, perfect color of white, and only 99 bucks on ebay. We had to holesaw the large caps on the back of the light, but other than that it was an easy install. took only 1 hour. The dude is in melbourne and i got them over night!
HID Kits r34
Very simple install and the result is awesome, my philips high beams do NOTHING!!!!
