Web page should definitely help. Also stops time wasters requesting pix and otherwise stupid questions that can be well covered in a website. Most who request pix just want to look at a skyline, not buy it. So if you put it all on a website that saves you that hassle I reckon.
Thing is people put skylines on here and wonder why it doesn't sell, but the majority of people on here own skylines, or you know about here because you own a skyline. Its like trying to sell ice to the eskimos.
Try other performance boards as well, especially those for smaller 4cylinder cars and things who might be looking for an "upgrade" to the world of skyline :(
List it for 15k, im sure you would sell it in a week...
Although ppl would probably then think somehting is wrong with it and keep their distance.Selling cars sucks!
Trading Post/Auto Trader/Unique Car Guide etc, purely because of their higher distribution, but can get expensive so perhap factor in the advertisements costs when stating your price.
Yeah Ive had my car advertised on the net and had no response through carpoint but when the Unique Cars publication with the same add came out I got heaps. They came as a package but all my responses were from the mag (with a color pic). The mags are good because many people dont know what they are looking for and the mags give them new ideas where as the net requires people specifically after your type and model. (if that makes sense!?)
Originally posted by outlawskyline
How much you want? is it gt wot? Just sold my 31' got an astra at da moment but not real impressed..... i want more power dammit!
Its a GTST with 320rwkw with alot of brand new parts. Should make more soon. I want 33k. From an astra to this, i reckon you would be frightened.
You car will get sold in no time on the TP, but their friggen expensive now.
I put in a 2 week advert for my old Daewoo and it cost $35 then stopped, I then entered it again for another $35 which ran for 3 weeks, then it stopped again. Rip off!
Go carsales.com.au, $10 until it sells.
depends which state.. certain people seem to favour certain publications in certain states for whatever reason.
I know in Melb the TP is a good one, and i've sold all my old cars through there. Current one will be in there soon.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
