I've got a t04e(i think or something near to that) on the side of my RB25.
Last night the turbo just started to whine really loud like a blender with nothing in it. The whine was reasonably high pitched and started when i reached 5000rpm.
The car hits the 13psi it's set to at 4300rpm so when it hits 5000 it's only just making all it's power... but it doesn't have any power at all now.
My Turbo is usually very quiet and i cant hear it at all when on boost. Only the sucking of air and the exhaust so it was noticable straight away that something is a miss.
Any ideas what could be wrong with either the car that's making the turbo whine, or is it the turbo itself?
We checked all the cooler hoses and the intake pipe (mine is metal) is still on.
I've got and ARC cooler.
Thanks guys!
ash
https://www.sau.com.au/forums/topic/25598-my-turbo-sounds-like-a-blender/
mmm... im thinking it is.
but could something else making it do it ???? (unlikely i know)
BTW anyone know how much a rebuild should cost ?
But then, i can get it 'tinkered' with too while it's off... and get some more out of it, this situation might not be all bad
one other thing.
My RB20 turbo was making a noise.
It turned out to be the gasket between the turbo and the manifold (on the block)
it seems that one of my bolts had fallen off and the heat at that corner started to burn out the gasket and eventially melt it and air was escaping through there and whining it's head off.
turbo was in perfect condition.
But if yours has a lot of thrust play (as in back and forth in to the turbo, not side to side), then you may have issues..
Although, a little play is normal.
If it is a gasket, it will set you back less than $50 for the gaskets and who knows how much to pull the turbo off and replace the gasket.
R31Nismoid, if you have to pull the turbo off, you can do it yourself. I've done a how-to in the Maintenance section, do a search. And since I've also got a T04E, you will probably be able to follow it word for word :(
my car done the same thing today.. sh*t my self.. stupid stocko bov caused it.. took it off and blocked up the whole and its all sweet.. check everything else before you go taking it off and getting it rebuilt.. could be a gasket? or a stuffed bov.. :(.. it was a wheezing noise when boost came on?
mmm... it's gotta come off now..
GRRR... god damit.
benny @ BMT says a bearing. and it's probably hitting the housing (hence the noise) so i could be up for mroe than a standard re-build...
me thinks a bigger housing :(
Have u made sure its not the obviouse though?
wouldnt want to be up for the cost of a rebuild only to find out it was a leaky gasket
make sure it gets proven to you that it is the bearing when the turbo is all off
i recently replaced my turbo with an aftermarket item...it was suprisingly easy to do :S
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
