Hello,
Looking for some advice on the above fueling combo.
I have a twin entry Tomei rail, and SARD 820cc injectors (lime). Garage phoned fee, fee emailed me so the info may be a bit skewed.
The connectors on the injectors have been trimmed to allow them to secure on without fouling the injector body.
BUT when it comes to fitting the injecors to the rail insitu the plug now fouls the rail, and tuner isnt confident the plug will stay if mounted the other way.
Anyone come accross this problem, they must have as its a tried and tested match.
You could always go back to the stock fuel rail :thumbsup:
Although interesting that it fouls the fuel rail, its it meant to be a replacement?
I know the SARD plugs need to be trimmed for GTR's, well, at least older models did as I have a suspicion I read something here stating that they don't any more (about 4-5 months ago)... but sorry I cant confirm that 100%
Ok. I'll add my two cents
I have just recently gone to a 11.0 Sard fuel rail (which should be the almost the same as your Tomei) with Sard 800 CC injectors. All i did was change the O - Rings to new ones. I didnt cut/modify or change anything else apart from that and everything seems fine!
Injectors are also lime green.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
