Awesome car!
I, myself took a while to find any info on it. The company is more so a tuning garage for Japanese performance cars and have done afew Euro cars and produce their own cars.
+ their website does not say much about it either and not much info at all on the AWD system tho...
All I know atm is the Tommy Kaira ZZ II was a $90,000 sportcar door coupe production car with a reverse mid mounted RB26DETT with 550hp (410.14 kW), 6 speed manual gearbox, does 0-400 metres in 3.3 secs and weights about 1500 lbs (680 kg) with 6pot front brake calipers and 4pot rear brake calipers.
It also featured front and rear aero diffusers, and a fully built roll cage.
IMO it is one powerfull and lightweighted fast car.
http://www.fast-autos.net/vehicles/Tommy_Kaira/2001/ZZII/
http://en.wikipedia.org/wiki/Tommy_Kaira
:D
Yeah I was suprised too, but its what I could only find on Fast Autos forum...
it was a fun car to drive on GT3 :laugh: well maybe not that particular model
Yes I was a fun car to drive in GT3.
I AM AGREEING WITH YOU! ;)
:D
LMAO! THANK YOU! :)
Thanks SKYLINE i already found out that much, i just want to know how to run the 26 gearbox in reverse and still have 5 forward and 1 revers gears :) keen on building something similar to a ZZII...
As they say "Crazy Japs" LOL! The things they do amazes me too and keeps me wondering.
All I can think of is they have modified the gear setup in the gearbox and the drivetrain...
Anyway all the best on your conversion.
To build one KISIN you would require a totally custom gearbox, the front diff in the sump could be utilised to drive the rear wheels, drive to that diff could be sent in the same way as a normal gtr (just backwards) and forwards to a front diff (which would usually be to the rear) but it would all have to spin backwards, lock the transfer case and be totally modified to have the H pattern shift the correct way around fro the driver. Then you would need to build the car, which you could build as a full spaceframe with intergrated roll cage, then glass fiber body, custom lights, fittings, glass etc...
If you were going to all this trouble you would probably want to register it as an ICV so you can drive it on the road, which, depending on your particular state you would need a suitably new engine, I think 3-4 years old or there abouts with the factory computer and emissions equipment...
You will spend well in excess of 6 figures, mabey even just for the gearbox, and it will take thousands of hours of custom fabrication. Good luck with the project KISIN, keep us all updated with a build log :thumbsup:
it's 0-60ks in 3.3sec..
Im sure they meant 0-100km/h in 3.3....
400mtr is a qtr mile...
Yeah my bad LOL! 0-100km/h in 3.3 secs. I don't know about the quater mile... Damnit can't edit my post...
In USA it would be 0-60mph in 3.3 secs.
Interesting... Sounds like you done it before?
Yes updates will be good.
Thanks for the reply. Ive already found someone that can build me a chassis and another for the body. Very good points you bring up, ICV - thats the path i hope to take, but 6 figures, maybe just for the gearbox ???
Apparently a company in the US can build this for me "no problems at all", however unless i see one of their models working, im not ordering anything with the aussie $$ this weak...to their credit though, ive seen their other work and its pretty damn good, even modified a lambo for SEMA...According to them, its piss easy to get it to work.
Just had a thought - the porche 4wd gearbox could be worth looking at, I think porche engines spin the right way, then the drive to the front wheels will be fine, H pattern is ok, the only trouble would be building an adapter plate to mate to the RB, and sending drive rearwards - you would need to remove the rear drive diff in the gearbox and send drive rearwards with a driveshaft - being very careful of final drive ratios, but they should be able to handle the power straight out of the box. Also you could even use one of the flappy paddle gearboxes for extra techy'ness.
*dont underestimate the cost of a gearbox for such a project - it will probably be the most expensive single part!
If you are keen to register it, talk to your local transport authority about building an ICV and they will point you in the direction of approved engineers to help you :D
Already had a chat to the transport department regarding ICVs and the gearbox is what im worried about the most !
hahaha.. post up pics of the build when youve got everything!
would be interesting to see it.
Well i have a fairly unique body *hopefully* getting made and right now i know there will be many haters because of what it will "copy" so to say...but im building MY dream car for ME :domokun: Hoping to have this baby done in a couple of years (yes couple, and thats pretty quick if you ask some others who have built cars from scratch). Pretty close on striking a deal with the US company, just the body is holding me back...you'll see why 1 day lol :) Until then buying an investment property to help fund this sucker !
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
