Hi guys,
I'm going to start clearing my garage today so will be selling parts, pics to come:
1) Apexi EL2 mechanical boost gauge (black face)
Reads in Bar, looking to swap for another mechanical that reads in PSI (pref apexi) of will take $170 for it.
2)
Turbosmart type2 V-port BOV, in good condition, makes a loud hiss, comes with r33 adapter (not sure what other cars this fits to).
$160
3)
Greddy BOV with cuton pipe. This item was purchased but never fitted to car, from what i understand in makes a SSQ BOV noise similar to that hear on Fast and the Furious (lol thats the only way i can think to describe it). Comes boted onto cold pipe for direct bolt on replacement onto R33 and can throw in some vaccuum hose as well
$250
4)
R33 GTST front calipers and rotors,
$350
5)
Aftermarket steering wheel, came off a s1 33, not sure of brand since centre is missing
$150
6) More parts to come + pics
PLease contact via PM,
Located Melbourne
Can deliver so most areas within Metro Melb
Pickup/delivery buyers given preference
https://www.sau.com.au/forums/topic/256591-for-saleswap/
Pics added below + more items added:
- B / C pillars left and right(left one has a small crack on end, both need cleaning) $80 each
- wiper stalk from 33 GTST $90
- indicator stalk from 33 GTST $150
- Pwr window control (pretty bad condition) $70
- The steering wheel brand is elevo
Negotiable on all prices
https://www.sau.com.au/forums/topic/256591-for-saleswap/#findComment-4421339
Interested in the Boost Gauge, except not for $170 as you can buy them off ebay brand new for $185.
I'll offer you $120 for it and can pick up asap!
Let me know, cheers.
Prefer a swap atm (since i will not have a boost gauge) but I'll keep ur offer in mind
Thanks
https://www.sau.com.au/forums/topic/256591-for-saleswap/#findComment-4435754
Would you sell just the front calipers without the rotors? If so then what price?
really want to sell together as rotars by themselves are worthless.
Guess I could do them for $250 by themselves if ur keen
Let us know
Edited by Taso84
https://www.sau.com.au/forums/topic/256591-for-saleswap/#findComment-4435755
What condition are the rotors in? do calipers the come with pads?
Yea calipers come with pads. Rotars seem to be in good condition but ur welcome to come and inspect. I'm not too sure how to gauge the condition of rotars.
Thanks
https://www.sau.com.au/forums/topic/256591-for-saleswap/#findComment-4445145
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
