Hey guys I wanna do up my r33 skyline gtst, I want extreme gforce power an obviously I want it to be very fast!
What will I need to buy ? All I have atm is an airfilter some cheap thing and an exhaust to the turbo.
Thanks in return
P.s I'm new to these forums an I'm a noob when it comes to buying parts!
Edited by Cenkz
https://www.sau.com.au/forums/topic/256623-help-needed-to-do-up-a-r33/
You will need at least a 1.21 gigawatt flux capacitor to make very fast extreme gforce power
Thats no longer enough, 1.21GW is no longer enough for todays power requirements, strap some extra flux capacitors & inductors & generators & aim for the 1 TW range.
On a serious note, do a search on the topic.
How much do they go for? Sorry for these questions, using the iPhone to get on here.
Also is that all I need ? I want to boost the turbo an I need a cooler I'm guessing :(
Yes yes, you need a cooler. An esky with built in seat and stubby holder should do the job nicely.
How much money do you want to spend? Cause that is going to determin everything. Do some research and find the best mechanic on a r33 skyline in your area (make sure they have done it befor). Don't worry how much they charge, because you will get it back in knowledge about your car. Then talk to them till they are sick of you, and then ask some more questions. Although it is good to go in with some knowledge so you have some idea whats going on. So I would read as much as you can this forum. I do find the info on this forum is in general better than other forums. Then work out a plan with your mechanic on how to get the best out of your car with what you can afford.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
