Ran over something on the way home and punctured my 1 trackday old re55. the hole in the tread is about the size of a pinky finger.....can't see down the hole to see how big the actual hole is in the tyre.
thoughts? repairable?....it's about 1/4 of the way in from the sidewall.
second option......who wants to lend me a 18" 265 35 for sat at eastern creek? unlikely to get a new one on by then.
Edited by tk80
https://www.sau.com.au/forums/topic/256638-punctured-re55-repairable-safe/
take it to a tyre shop and ask them?
i usually wouldnt reccomend getting advice from a tyre shop, but they are really the only ones that can tell u whether its repairable or not as they will be able to inspect it and they will know whether they can fix it or not.
Take the tyre to a type place that deals with motorsport tyres like this and they will tell you if its repairable depending on where the hole is.
It isn't recommended that these tyres are repaired however I have had a puncture repaired on an RE55 and so has Aaron34. Mine suffered no ill effects at around 200kmh around turn 1 at PI and Aarons beast tested his at around 300kmh top speed and around 1:45min lap around PI :)
As long as the puncture isn't in the wrong spot you should be fine :)
how big was the hole in yours?
i reckon i hit a bolt or something....hole could be 8mm....that's how big the hole in the tread is.
i ran over a screw once on re55's got a hole and no spare tyre, well i tired the sopace saver but the car didnt like it at all.... drove home about 15km's slowly.. the sidewalls are nice :) but the tyre was a wreck since driving on the sidewall i wouldnt use it again.
I had a self tapper bolt in mine although I think it was around the 6mm mark. Tyre places have diff sized plugs to suit but I would go to a place that knows re55 rather than just any tyre shop.
As for driving on flat re's...yep the sidewall will get you home depending on distance but you can throw away the tyre for sure.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
