Hmm I don´t realy know what to do with the car in future, Maybe I should buy a 3 inch system and if I go over 300rwkw buy a 4 inch ?
I have looked on this system http://www.japspeed.co.uk/Nissan-Skyline-R...tem/p-21-1-280/
What do you guys think of that ?
And I have looked to this one to
http://askas3046.dedic35.kontrollpanelen.s...kr&Visn=Std
The text says
4””two piece sportexhaust (3,5" at the first flange)Catback system. Endpipe dia. 4.5”
Flanges in steel and pipes made in high quality (SUS304) stainless steel.
The price of them is about the same.
I want the car to sound mad and angry. I also have an apexi intake on it.
Edited by Turbo_Knuff
The text says
4.5"?!?! are talking about an exhaust for your car or a drain pipe for your house...
it had a largish middle muffler, and a 4" inlet, 4.5" tip cannon on it, it was also very straight too (no gay angle mounted cannon), when the car got rear ended, the exhaust still stuck out due to no bends to kink on...
it was a few years ago when it was tested, but i think they tested it at 4,500rpm, and it passed.
it did get a bit louder higher up, but normal driving wasn't loud and droning at all.
Some of the jap ones are actually very very quiet. Im unsure of the brands however.
Ive heard some that are only marginally louder than my custom one... being the only option for me is custom.
So you can certainly get some quiet ones, the two muffler setup ones
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
