Hi,
Ive started getting things together for a 26/30 build, much like huddy.
so far ive got the block and head
BLOCK
rb30 series 2 block
new welsch plugs
crack tested
boared and hoaned
new bearings
reground crank
new main seal
new water pump
new h beam conrods
arp main bolts
arp rod bolts
cp forged pistons
cp piston rings
rb25 oil pump
ATI Balancer
HEAD
GREX 264 9.15 cams,
ported,shimmed
not 100% on springs
external oil drain
im going to be using a surge slotted TO4Z with .84 housing, 44mm gate,
now i want this to have some power,400kw maybe.... :banana: obviously it wont be always tuned like that..
so i know ill need to upgrade the oil pump,
is there anything else you more experienced people can help with?
cheers, ill keep progress updated
Edited by jangles
https://www.sau.com.au/forums/topic/256707-another-2630-build/
-Sell the cams, get something more suited
-Agreed with Shane
-What manifold will you use? ebay or something like a 6 boost? (I used ebay and it was fine, BTW a 44mm gate and to4z sounds awesome when its loaded up)
-Make sure the thrust on the crank is ok and that the crank is usable, there's SO many stuffed ones out there
What car is it going into?
-Agreed with Shane
Not sure why it hasnt been decked, but am going to get it done, i bought the block already built.
yeah will def have restrictors
what sort of cams would you suggest?
nah wouldnt bother putting it in just to pull it out to change oil pump, will be done before it goes in.
will be using a 6Boost manifold
what do you mean by making sure the thrust on the crank is ok?
Edited by jangles
270's or 272s' with 10.25mm lift would be a good start - or even 280's. Get as much lift as you can. Dont forget springs aswel
Yes the thrust on the crank, it will be in a lot of trouble if you have a clutch with a big clamping pressure so get a clutch that matches what you want and isnt a heap of overkill
I learnt that lesson about not checking for end float :( Had to pull the engine out, cost me the crank machining, new set of mains and a new oil pump.
If it wasn't caught when it was, would have been up for a new block aswell :D
Edited by bubba
Tomei oil pump is a must have for big power engines. (not that I can afford one, its just a suggestion)
You should probably start getting all the fittings and small stuff now because it can all stack up to big $$$ and you dont want to be buying crap hoses or belts because you already spent all your cash on the bigger expensive bits.
(Redline oil, bigger sump, high flow braided oil/water lines and fittings, second belt tensioner, quality silicon joiners and hose clamps, high tensile bolts for clutch, locking nuts for turbo, good turbo gaskets, high flow intake setup, breather system and catch can, etc).
Another thing you want to keep in mind is engine bay space, my RB30/26 with high mount T04z hits the cam cover on the strut brace and the turbo has 2mm to move before it hits the strut tower. This is in a R32 gts-t.
If you want 400rwkw's and you want it to last you have to be willing to spend some money.
You should probably start getting all the fittings and small stuff now because it can all stack up to big $$ and you dont want to be buying crap hoses or belts because you already spent all your cash on the bigger expensive bits.
yeah, i know, little things do add up,
im looking at one of the external pump set ups on here at the moment,
id rather do it right the first time
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
