OK, I've got my Bilsteins, got std top caps, king springs [progressive], and some new rubber bumpers and gaskets etc. All x 4.
What I need to know:
1. I have two types of std top caps, they are exactly the same but two have 6mm studs and the other two have 8mm, which is front and back, guessing 8mm is front?????
2. The spring rings on the billies are different, guessing the large ones are the back ones and the smaller ones are the front???
3. The springs are about 30mm different in length, logic says the short springs match up with the shorter Billies and they are the front shocks????
4, There are two sizes in the top cap big rubber rings, they are the same dia. all over, but one is thicker from top to bottom than the other, thick ones to the front????
Can anyone confrim this for me please.
I'm working off a printout of the parts manual for the Skyline and a brief instruction sheet that came with the Bilsteins, trying to combine/meld the two into one set up. Have to say that japanese and german [the axis powers] didn't make it too clear!!!!.........lol
https://www.sau.com.au/forums/topic/256761-assembling-my-bilsteins/
I haven't taken the Teins off yet, just wanted to assemble the Bilsteins and have them ready to go when I started the install.
I think I've got it now anyway, not positive, but things seem to fit. For anyone else:
1. 6mm to back
2. Yes
3. Yes
4. No, big to back
Well thats what I've done and it seems to be going together OK.
As an aside, I ordered new gaskets, bump rubbers and dust covers with the other bump rubber as a unit. Part numbers:
Top bump rubber 4 x 56217
Middle bump rubber 4 x 56218
Dust cover/gaiter with fitted bump rubber 4 x 54050
Gaskets 4 x 54329
That should be enough to replace all your rubber parts etc.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
