1 word... greek..
with out any slippery assistance.
trust me on this one ok.. dont go there.... ever... that saying about girls on there rags.. somthing like when it goes red go brown... u tell them to ggf..
i was in pain for a week!!!! couldnt piss with out crying
  • Replies 74
Originally posted by Zdenko
i think if it did ...a right hook would be involved on my behalf
mmmmmm, can we all say misogynist?
Speaking of braces, when I was 12 I once managed to get mine caught in the carpet. Not the "good" carpet but the stuff on my floor. When dad finished laughing he got me a knife so I could cut myself loose.
I got a couple - not as good as some - anyway....
When I was 18 - schoolies week up in Qld - went on the waterslide - decided to be a smartarse and go down the slide on my belly - So I launch myself over the thing you are meant to sit on at the top of the slide - and guess what - I land on my face - busted all four front top teeth off at gum level - Worst pain in my life - 4 tooth nerves exposed to cold water and air - Went to the dentist and he put like araldite or some shit over the busted teeth so the nerves wouldn't be exposed - Had to drink Beer through a straw for the rest of schoolies.
Another time, I was climbing a 9 foot brink wall - just about to get over the top when I lose my grip and footing - I fell and my the bit just at the bottom of where my nose meets my lip took the full force and implact of the corner of the top of the brick re-inforcing pylon thingy - blood everywhere.....
Well, this has proved to be a most interesting thread. My thanks to everyone who contributed, you are all very special people.
It even drew some folks I'd never even heard of before.
Hopefully they will feel compelled to post in my next thread. As to what that will be, You'll just have to stay tuned. I will endeavour to make it as entertaining as this one has been.
However we must keep these topics freash and we'd hate this one to stagnate wouldn't we?
Thank you all once again, I now call on one of the mods to close the thread. Nark, James would you please do the honours
:burnout:
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
