whos to say they can be skimmed? with normal wear and tear you'd be lucky to skim once say if your car done 100,000km!
+1 upgrade fronts
p.s i dont think its that cheap to skim discs... takes a while to get them even again like they do 1 side a time... takes like a 1hr for fronts
  • Replies 43
With normal wear and tear you will never need to skim rotors.
Skimming is only required because of abnormal wear and tear.
A. TAKUSHI, why did you quote yourself? (Twice)
Because im making a point and someone who spends that much time on sau alone needs to get out and experience life once in a while, not tryin to sound like a dick but damn thats alot of free time and to miss my point in my 1st post
C. From my 1st hand experience, when i imported my car i was told "all of your rotors need to be skimmed", 3 years later... same rotors, same pads, no skimming, still going (40,000kms.)
Again depends on driver, you hammer your brakes, you'll chew them out quicker and glaze them up, if you fit a metalic compounded pad they'll chew out your rotors quicker and yes ive never had to skim my discs or change my pads but thats coz driving a manual has its advantages
Anyway, if skimming was sooooo bad, why would it be an option?
But seeing as you asked, skimming is just the cheapest way of getting more life out of your brakes. buying new rotors, in the end, saves you money
im saying a brand new disc will last longer than a disc thats been skimmed,
You do rotor/drum/flywheel machining at your work place or just replace with new items all the time ??
whos to say they can be skimmed? with normal wear and tear you'd be lucky to skim once say if your car done 100,000km!p.s i dont think its that cheap to skim discs... takes a while to get them even again like they do 1 side a time... takes like a 1hr for fronts
Both sides should be machined at same time and machining costs $18 a rotor and dont take 1hr to do ( if it does then there retarded ) Takes me 10-20mins to do a set :)
We have a machine that gets regularly used as most people either dont have the money or they decide against new rotors, we give our all our customers either option and they decide on what they want to do, we skim discs but not drums-machine fitting for that went walk about long before i started work there and as for flywheels we send those away
How many come back needing to be remachined ??
Aside from the utter bullsh*t posted above (feeling like a retard yet takushi?)
How do you know if your brakes require skimming/machining? Is there a rule of thumb?
It can't be just pedal feel/pulsating surely?
I've got small grooves in my discs, and a small ~0.5mm raised edge on the outer circle of my discs (where the pad doesn't bite the disc) - maybe it needs skimming?
If your having pads replaced we advise on machining as rotors never wear even ..
Also prefer to machine as theres less chance pad noise due to glazed rotor ..
As for lip on the rotor if you were replacing pads i suggest you machine them if there above the replacement thickness ( most asume its minimum machining thickness )
hahaha oh dont make me laugh dude haha 1st your saying- whats been said is utter crap, then you ask how do you tell if they'd need machining, c'mon mate stop being a keyboard warrior and actually read whats being said, im actually giving out much needed info, or this poor the sphincter of the universe will go out and get whatever done which might not be the right way, the guy asked for info so i gave it, people got a prob with it then maybe they need to go to tafe for 4 yrs
And yes grooves and lips on discs do add to shortened pad life so a machine could be a good option on your next pad change
Also dsturbd yeah we've had a couple of people come back bout 6 months or so later saying theres pulsation again but thats only been with the falcons and commodores and one case with a discovery 3 landrover, and we only machined their pads coz the price of discs was a bit much for them at the time
So the problem cars i mentioned have been the 1s to return :laugh: As for the Landy did it have pulsating pedal before machining was done ??
Nah just massive lips, once the machine was done, it only just came to over the allowable limit, for some reason european cars chew out their discs quick aye, get shit loads of astras doing it
if you just need some normal std rotors rda make some very affordable new rotors , not really worth going 2nd hand at their prices
if theres meat enough to skim them skim them , even if you get another 6 months at 20$ each does it matter . then its time for new ones
mmm now i think i remember bubba on here put 34gtt rims on his 32 after putting 33 calipers on and he needed 5mm spacers that made the rims just clear on the front, not sure with 32 stockers though, if you're reading lyell wana shed some light? Haha
Interested to know why it needed spacer ..
On the 34gtt rims, in between each spoke is a little bit the pokes back in towards the hub.. when I first put the 34gtt rims ons, the little bit in between the spokes clamped up on the stock calipers. I had to use 3mm spacers to get the rims to clear.
When I put 33gtst brakes on (296mm rotor as opposed to 280mm) the caliper sat out further from the centre enough that the little pokey bit on the rims cleared without spacers. And when I say cleared.. there was like 0.5-1mm of clearance.
Now running 327mm rotors with 33gtst calipers on dogbones, barely fit inside the 34gtt rims :) now I'm got some 18s on there so the brakes should be getting a lot more airflow.
In summary: I've never had stock 32gtst rims so I can't really say.. 33gtst rims fit over them fine (obviously) and I think they're a very similar size to the 32gtst rims.
Edited by bubba
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
