Item 1
Genuine RB25DET Trust-Greddy Intake Plenum for Skyline R33 GTS-t.
This is not a cheap Chinese knock-off, don't be fooled, cheap inefficient knock-off's will cost you over $500 plus the issues of fitting and aligning. Also known for not delivering expected performance. Comes with PCB valve and other necessary custom attachments.
Asking $500 (replacement cost over $1500).
Item 2
Nismo/Sard 850cc side feed/high impedance injectors with collars for R33 RB25DET, less than 2000km use in 3 years. In perfect ‘near new’ condition, clean and can be fitted as is!
Injectors are fitted to a polished stainless steel Nissan fuel rail and have an upgraded Apexi adjustable rising rate fuel regulator. Comes with its own electrical harness.
Asking $800 (replacement cost is over $1800).
Item 3
HKS 264 Cam Shafts (Intake and Exhaust), 264 degree and 9.0mm lift.
Asking $800 (replacement cost $1200).
Item 4
HKS Adjustable Cam Gear (Exhaust only).
Asking $100.00 (replacement cost $350).
Item 5
HPI Engine Dampener for R33 GTS-t.
This item is perfect to reduce torque loss due to engine movement. Solid Engine mounts are noisy and cause far too much vibration through the cabin.
Asking $200 (replacement cost $350).
Item 6
Aluminium Radiator Deflector / Cooling Panel for R33 GTS-t.
Asking $100 (replacement cost $250).
Item 7
CUSCO Brake Booster for R33 GTS-t.
Increase your stopping power by removing unnecessary brake movement.
Asking $100 (replacement cost $200).
Item 8
Heavy duty, high performance oil cooler and oil filter relocation kit for R33 GTS-t RB25DET.
Significantly reduce oil temperature whilst relocating your oil filter to somewhere easy to access. This item is perfectly suited for those using the aftermarket Plenums.
Asking $500 (replacement cost $1200)
Item 9
Splitfire Coil Packs for RB25DET.
These coil packs have done less then 2000km, they are practically new.
Asking $500 (replacement cost $700)
Location – Brisbane (South-side)
Item Condition
The following items have been on my car for approx 2 years and have done less than 2000km in total. All items are in perfect 'as new' condition. Car was a show car and never raced or flogged.
Reason for Selling
Parts are surplus as the ‘show car’ they were on has been de-modified.
Price & Payment Condition – AS LISTED AGAINST EACH ITEM
Extra Info
All serious offers will be considered, if I do not reply to you it is because I do not consider your offer serious or reasonable. Only make an offer if you are intending to buy the turbo set up. Also, I will not reply to you unless you include your full name, telephone number and your address. Please don’t waste your time or mine.
If you can get a better price then this buying it from your dog’s third cousin’s friend on your great uncles side…then do it and please do not waste my time!
Contact Details
(1) You can reply to this post;
(2) You can send me a Personal Message; or
(3) You can call me on 0414 575 676.
Pictures – As attached
Item 1
Asking $500 (replacement cost over $1500). ON HOLD PENDING PAYMENT
Item 2
Asking $800 (replacement cost is over $1800). ON HOLD PENDING PAYMENT
Item 3
Item 4
Asking $100.00 (replacement cost $350). ON HOLD PENDING PAYMENT
Item 5
Asking $200 (replacement cost $350). ON HOLD PENDING PAYMENT
Item 6
Item 7
Item 8
Item 9
Item Condition –
Reason for Selling –
Extra Info –
Contact Details –
Thank you to everyone for the interest in the parts. Sorry but many of the parts have been sold. I wish I had more but I only have what is listed left.
Again thanks to everyone.
Item 1
Genuine RB25DET Trust-Greddy Intake Plenum for Skyline R33 GTS-t. SOLD
Item 2
Nismo/Sard 850cc side feed/high impedance injectors SOLD
Item 3
Item 4
HKS Adjustable Cam Gear (Exhaust only). SOLD
Item 5
HPI Engine Dampener for R33 GTS-t. SOLD
Item 6
Item 7
Item 8
Item 9
DAMN T I WISH I COULD GET THOSE CAMS OFF U BOY IM DROOLING OVER THEM AS WE SPEAK LOLZ damn auto is on the way out now so i gotta get that fkn fixed if ya still got em when i get some money together ill probably get them off ya mate...... u got my number and i got urs ill give ya a buzz when i got the cash for em..... that is if u dont sell em
UPDATE OF PARTS LEFT - EVERYTHING MUST GO ASAP
Item 1
Item 2
Nismo/Sard 850cc side feed/high impedance injectors with collars for R33 RB25DET. SOLD
Item 3
HKS 264 Cam Shafts (Intake and Exhaust), 264 degree and 9.0mm lift. [b]SOLD[/b]
Item 4
HKS Adjustable Cam Gear (Exhaust only). [b]SOLD[/b]
Item 5
HPI Engine Dampener for R33 GTS-t. [b]SOLD[/b]
Item 6
Aluminium Radiator Deflector / Cooling Panel for R33 GTS-t. ON HOLD
Item 7
Item 8
Item 9
Splitfire Coil Packs for RB25DET. SOLD
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
