I had a great day although rain for the first time I have driven a car in 7 months was a kick in the face!
Had traction issues all day (excuses) so I ran gate pressure all day and was a fairy with the throttle (You think a Trust setup sounds good, it was nothing compared to when they are on full song!) as there was no point trying to put down all of my power.
I will be back for a dry run and try to take off at least 10 seconds.
Once again awesome day, and the photo's from you guys show just how awful the conditions were.
Forgot to say big thanks to Copnis for his help on the start grid, you were out there in the rain for ages, doing a great job. Thanks heaps.
Official results are below, and even though Brent is the Motorsport secretary for CSA, we are not going to let him race any more, in the true Australian motor sport tradition, we are banning him. Anyone who is fearless enough to go out in that weather in a Fiesta XR4 and win is a nutcase hehe.
Well done everyone, only a couple of harmless spins and no bent cars in what was very slippery conditions.
Anyway Official results below as promised.
Track: Wet
Fastest Time of the day P.Milvain Skyline R31 66.71
Class A Standard NA
1st B.Edwards Ford Fiesta XR4 70.29
2nd C.Starr BMW M3 71.98
3rd M.Zanini Skyline Fire Engine 75.33 (74.12 in Caz' GTS2)
4th A.Deangelis GTS Shilloette 78.99
5th A.Bilston Holden VK Commodore 80.38
6th K.Kruger Skyline GTS2 90.24
7th R.Grist Nissan Bluebird 92.35
Class B Standard Turbo
1st P.Gleason 180SX 73.14
2nd J.Richardson Skyline GTSt 74.90
3rd G.Bishop Stagea 75.36
4th T.Barber Skyline 77.92
5th P.Rowlston Datsun Bluebird 80.13
Class C Modified
1st D.Zalstien 73.14
2nd J.Smith 74.70
3rd M.Demsey 76.07
Class D Race/Super Modified
1st P.Milvain 66.71 (TFD)
2nd G.Cook 67.44
3rd S.Coulson 75.40
4th K.Coulson 81.19
This was a well run and well organised event, and big thanks to Gippsland Car Club, who have once again, invited us back.
Winton in September looks like I am out there again. Check the CSA Website for Pricing for WInton which is now out.
just a few teasers. will loac them as soon as i get time. not alot of good pics but just to show some others what it was like.
Stupid car didn't want to play ball this week, so I bravely spent the day looking like a Traffic Cone with my Dayglow Orange Jacket on :slap:
Have to tape glass headlights, so that if they break, the glass doesn't fall out onto the track. Just a precaution.
We all got heaps of runs TETS, was fantastic.
We are hoping for another one very early next year, so stay tuned.
Looks like a fun day in the wet.
I was there on the sunday and it had dryed up by then.
Anyone have more details about that R31 GTSR? is it genuine? There are a few things on it that make me think it used to be my old car.
Also which car is Paul Milvains? I work for the same company but haven't heard much about his 31.
Also I laughed when I saw the camry badge on the Chaser haha.
You will find that the bright yellow Coupe is Paul's 31, and that ain't no GTS-R, tis Wheezy ex black on Gay coupe :D
Sweet.
Well I think that may be my old car. How long has he had it for?
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
