I ended up picking up Killzone 2. Online play is epic!
Resident Evil 5 seems alright, I've played previous titles didn't really get into it. My bro will probably pick it up so I'll just steal it off him :banana:
Don't really like playing shooters on consoles,
shooters are only good on PC in my opinion.
I like adventure games more on consoles, God of War is strategic, has a very good story line and has three parts to it, so you know there is really a good audience behind the game. My favorite console game by far.
But always try out a game before you buy it to see if you like it or not.
i like KZ2
BUT
i dont get it
like
are we invading a country? i don't understand it like, what are we fighting? are they aliens? why do they speak english?
i want answers
ahem....
someone answer my question pls
Killzone 2 follows the events of Killzone and Killzone: Liberation, and entirely takes place on the planet Helghan, the home-world of the Helghast, who invaded an Interplanetary Strategic Alliance (ISA) colony. Two years after the Helghast assault on Vekta, the ISA has launched an assault on the enemy's homeworld of Helghan. The ISA goal is to capture the Helghast leader, Scolar Visari, and bring the Helghast war machine to a halt. Players assume the role of Sergeant Tomas "Sev" Sevchenko, a battle-hardened veteran of the special forces unit Alpha Team, who go on a mission to take out the Helghast threat.
During the invasion of Helghan, Sev's unit is deployed behind enemy lines to assist the main invasion force. Tasked with securing the enemy capital of Pyrrhus, the team quickly discovers that the Helghast are a more formidable enemy on their home planet. Not only have they adjusted to Helghan's hostile conditions, they have also harnessed the power of the freakish lightning storms that always occur on Helghan which they can now use against the ISA. A cold, barren, unforgiving world, Helghan provides a ready defense with thick, acidic air, dust clouds, and violent surgical lightning storms. Sev discovers his squad is not just fighting enemy forces – their fiercest opponent may be the planet itself
http://en.wikipedia.org/wiki/Killzone_2
Mr Eps (Sperm) you should be shooting at the ladies not video games... LMFAO! Had to say it. :thumbsup::banana:
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
