Wouldn't usually post stuff like this, but just in case...
I received this email from a mate;
BEWARE OF PAPER IN THE BACK WINDOW OF YOUR VEHICLE
NEW WAY TO DO CAR JACKINGS
(NOT A JOKE)
You walk across the parking lot, unlock your car and get inside. You start the engine and shift into Reverse.
When you look into the rearview mirror to back out of your parking space, you notice a piece of paper stuck to the middle of the rear window.
So, you shift into Park, unlock your doors, and jump out of your car to remove that paper (or whatever it is) that is obstructing your view..
When you reach the back of your car, that is when the car jacker's appear out of nowhere, jump into your car and take off.
They practically mow you down as they speed off in your car.
And guess what, ladies?
I bet your purse is still in the car.
So now the carjacker has your car, your home address, your money, and your keys.
Your home and your whole identity are now compromised!
BEWARE OF THIS NEW SCHEME THAT IS NOW BEING USED....
If you see a piece of paper stuck to your back window, just drive away.
Remove the paper later And be thankful that you read this e-mail.
I hope you will forward this to friends and family, especially to women.
https://www.sau.com.au/forums/topic/257537-paper-warning/
Agreed... But that would require common sense, something that the majority of our populace is missing (or choose to ignore)
... or find piece of paper on your window. Drive off a bit anyway. See who comes out of hiding, then reverse and run the f**ker over! :wave:
https://www.sau.com.au/forums/topic/257537-paper-warning/#findComment-4432364
i would agree not everyone would see it .
alot of people come hard on from the side, only a small amount come from behind and thats when they forgot where they parked
TJ, is this really the place to describe your bedroom antics!
Edited by iamhe77
https://www.sau.com.au/forums/topic/257537-paper-warning/#findComment-4432545
Damnit dude! Why'd you have to go tell everyone?! All I ever wanted was 16 Stageas in my driveway (don't ask me why), and now what chance do I have?! Sheesh: some people......
In all seriousness, it's not a bad scam: I don't think most people would notice it on the way back to their car, and most would probably assume it was a worthless piece of advertising if they saw it once they were in the car. The Police beat at my local shopping centre used to leave a slip under the front window wipers either congratulating you on having locked your car when they checked, or chastising you for leaving it unlocked ( I believe they actually tried to lock unsecured cars, if they could)...
https://www.sau.com.au/forums/topic/257537-paper-warning/#findComment-4432556
yep i upset some people , but you cant be pleasent all the time, the twisted side of me comes out at times , and people are like what the f#%K. some gett really offended and dont want to associate themselves with me , its all tongue in cheek just depends how far one's mind ventures off the beaten track , so if i offend so be it !!! but dont take me seriously guy's , :):P SORRY
https://www.sau.com.au/forums/topic/257537-paper-warning/#findComment-4438268
holy crap, is it really that bad down in melbourne? gees our car stealers up here arent that smart, they're flat out stealing a commodore.........
thats unlocked! lol. nah that mostly just break the drivers window or sumthin.....
they aren't very professional up here thanks god, and prolly just think my car is a crappy volvo anyways :P
https://www.sau.com.au/forums/topic/257537-paper-warning/#findComment-4438624
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
