  • Replies 2k
Ghostrider, because it looks sooooooooo much better than the TI grille which is very ghey
Ta for the info, I figured that since the honeycomb one is also on the PNV's that it must be from the TI's
I went through a whole lot of Jap pics and decided that I like the 3 slat grille the most. Also saw a few lower front spoilers I really like, but getting them aint gonna happen.
Does anyone have any idea on where to get some bolt on flares from? And do the Japs cut out the inside of the guard when they fit the flares? I know that HDT did it with the VB's or VC's that had the flares
I'd like the flares and I could get my rims widened
it requires you to send the crosmember and trailing arms over to them, not bad though
I just contacted them by email & BAZ replied, ONLY FOR 510/1600's, doesn't know of any ARC's for R30's.
Can your info be confirmed?
anyone in adelaide got a spare black thingo that goes above the rear bumper and under the lights. its like a continuation of the mouldings around the sides...
Good luck, I search Sydney wreckers for them all the time. If they're not damaged from accidents, they're bubbling from rust, from the backing and clips.
In about 5 years I have found 3 that are perfect, and those 3 are now drowned in fishoil.
In your search, be aware that 81/82 are different to 83/85.
spewin
These are available through genuine Nissan parts for $112 Trade price..... I reakon thats a good price if your in need of one!!
That's an excellent deal, considering they want $8-10 for a wheel stud.
hm........ dunno if my car has that
Certainly Has!!!! they all do!!!!
Coupes, Sedans, Hatches, Jap imports & Aussie delivered, they all got one.
To you it may appear to be part of the rear bar, but it certainly is there.
Check Thumbnail!
If you look closely on the thumbnail, just left of the bottom left corner of tail light, you will see a bubbly section. THIS IS RUST in the support bar and it looks UGLY if not FUGLY and the clips rust and break.
GOOD 2nd hand is hard to find and NEW might be a better alternative.
Mike,
Is yours the same as pic?
ADJUSTABLE REAR SUSPENSION
Baz from DatSport in Adelaide will modify or make up the jig to make the R30 Suspension FULLY ADJUSTABLE, if we can get 8 people willing to get the job done.
DO WE HAVE EIGHT (8) on this forum that want's the job done????????
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
