We can't wait any longer to find an ecu for our S2 Stagea auto. The std ecu couldn't be fixed (BUGGER)! Have rang lots of wreckers with no luck and my local nissan can't even get back to me. We are going to have a Vi-pec ecu board fitted next week. It is going to clean out the piggy bank but I am looking foward to driving wagon again. I am going sell the Apexi SAFC and Jaycar boost controller that are wired in. I will sell Apexi Multi checker also if it can't be used. It will be interesting to see what wagon goes like. I have just o'hauled head after head gasket letting go on no. 6. At same time I match ported manifolds to head. While in machine shop they dedaged seat to port machining steps and smoothed chambers. I had injectors cleaned. I also fitted an adj. ex. gear at the same time as fitting a 100k km timing belt kit. Wagon allready had a k&n panel filter, full 3" exhaust and was running 10lbs boost. Head gasket blew 2 days before new years and wagon has been off road since. I am going to the blow cobwebs out once we get it tuned!!!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/
Sounds exciting. I have been told that the Link (same as the Vipec) can handle autos (i.e. retarding timing etc during gear changes). I haven't taken it further because I can't afford one just now and I have found someone to make my ecu tunable but I believe you may need the top of the line model to handle the auto (but maybe not). I look forward to your results. If it goes well your car should fly with the stock turbo (more airflow for the same amount of boost) but you will also be set for a turbo upgrade in the future. keep us posted!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436361
I've been told the same thing from a Vipec dealer, which is good news because I was just told by the Haltech people that the e11v2 will NOT talk to the stock ecu. The only way to get the Haltech dropping timing on shifts is to attempt to intercept a signal from the gearbox when it changes gears and set that up as a flat-shift function in the Haltech :P
Keen to see how you go skidkid!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436617
surprised you didnt grab a chipped one from yahoo japan.
tested a S1 one recently, worked a treat, and the fella also had a S2 unit coming as well......
so they are around, used S1 or S2 ecu's chipped for Rom tune in Japan.
grab one, use safc to sort out the tune on your own car, and go from there? around $300 a unit.....
anyway best of luck
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436717
I have been assured that the Vi-pec will run our S2 with an auto. If not I will not pay for it and I will have to hurt somebody!! Tangles; We decided not to go 2nd hand ecu because no warranty and Vi-pec can be tuned to our mods!!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4437075
Ouch! :laugh:
$1760 for an ECU which is in my opinion one of the best available and is over $200 cheaper than a GTS-t Apexi Power FC which is quite a basic ecu compared to the Vi-PEC.
$750 for tuning
seems the going rate really...quality costs money
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4452631
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
