Top tank looks to be leaking, cracked or a seal-unknown as yet... am i better off getting a 300$ alloy rad? does this affect the auto trans as it will no longer be running thru the rad?
as i have been quoted more for a new top tank, seal and a cleanout than a JJR GTST alloy rad will cost.
standard trans cooler, but i think it just runs thru the rad to warm it up?
-Ryan
https://www.sau.com.au/forums/topic/257907-radiator-woes/
-Ryan
Buy a second hand radiator from a stagea, I happen to know were to get one :P
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4436829
-Ryan
Your radiator place should be able to supply a bigger capacity radiator which has connections for the auto fluid. The point of going through the radiator is to bring it up to operating temp quicker - most trips are short ones.
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4437558
that is what i was afraid of.
i've had enough, gonna try and get a credit card, fix all the small shit, and get another datto or something and pay off the loan with the difference... rare cars shit me, i was quoted 400+ IFF they can find a top tank
other idea is run a reco'd r33 gtst auto rad, think they are 10mm thicker
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4437957
The rad. i bought was a replacement to suit a stagea and the bonus was it is 25mm compared to std 16mm. It was 'brand new' at $450.00, alu. core. I had to sell my little left finger to pay for it. I have used rad. socks for years now. I took sock out today to see what it had caught. It had a heap of head gasket i had scraped and lost into water jacket plus some machining swarf. It came with rad. Prior post on head gasket story.
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4438512
ouch
but not much more than i was estimated by a rad guy... where did you get it from? gen nissan with the auto hose thingo?
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4438528
Hope the half a job doesn't let you down. Been down that road a couple of times and found its not worth the money and time.
if it lasts me two months(when jayrad will have units in stock), i will be happy.
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4448096
Did you fit a 'Radiator Sock' when you put rad. back in? They save alot rubbish blocking rad.
crap nope, care to elaborate?
apparently the guy has bench and lab tested a LOT of coolants, and uses an organic(non-glycol) one, as it doesnt block the rad and has light cleaning agents in it!
https://www.sau.com.au/forums/topic/257907-radiator-woes/#findComment-4451558
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
