Hello to all you skyline Guru's.
? Im in need of a O2 Sensor for my rb20det that's in my s14?
I heard that you can use a O2 Sensor from an CA18, it would be great to get some input on this because they are fairly cheap and easy to get.
Im looking to do a tune up and want to change as many parts as possible.
If anyone know's of any other interchangeable parts that are sold in the in the US please be kind as to inform me.
Thanks in Advanced.
https://www.sau.com.au/forums/topic/258217-please-help-i-live-in-the-usa/
CA18DET O2 sensor part number is 22690-36F00 or B2690-12P01
RB20DET (R32 RB20DET's anyway, ceffies and R31's etc had the Series 1 RB20 which used a different O2 sensor) use 22690-73L11. I'd hazard a guess that SR20DET's use the same one, but that doesn't really help you out in the US cos you don't get many of those either.
You can ask the guys at Kudos if they'll ship to the US
http://www.kudosmotorsports.com/catalog/pr...;products_id=42
yeah, i wish moving was an option.
as far as the sr20 02 sensor if anyone can back this up, i have friends with these motors laying around.
Off the subject, anyone have the part# for the oil filter or can i use the 300zx, and how much motor oil is used for the oil change?
sorry for all the newbie ?'s
You might want to do some more research, but my best guess on an O2 would be a Z31 turbo or an S13. The connector will probably be different, but you can switch out pins.
I used a 96 J30 oil filter on my RBs. I think it's the same as the S14 KA too.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
