a guy jumped in front of the train entering edgecliff station (bound for bondi). He "stuck" to the front for a bit, then
slid down & underneath.. train stopped after 2 carriages had entered the platform.
the surprise was how much people just sorta stood around. Train driver gets on the phone. People on the train
just sat there (they couldn't get off I guess without a decision on the doors). Train didn't back up. Station staff took
ages to come down. Two women just sat looking traumatized. No sign of cops or ambulances 15+ minutes. I didn't
particularly feel like hanging around to see what was left, so headed to the buses.
I guess the lesson is that if you want to end things this way, don't expect medical attention for a good half an hour
if it doesn't fully work out..
https://www.sau.com.au/forums/topic/258424-i-saw-a-suicide-today/
i could be wrong. but i doubt anyone who jumps infront of a train would be very interested in seeking medical attention. kinda goes against the whole "killing yourself" thing lol
on another note, i had the same thing happen at bondi station less then 2 yrs back. sum bloke sitting casually on d bench waiting for the train then as the train approached the station, he launched himself infront of it
Oh my gosh thats messed up...
A friend works for the railways dealing with the report for exactly this and you would be amazed at how often this happens really. Almost on a daily basis just around Sydney, i seen a guy jump of the overwalk bridge at Lidcombe station directly into the path of an oncoming train about 6 months ago.
I feel sorry for the ppl who have to see that sort of thing :(
Whilst doing some work transfer for EDI rail I heard a ton of stories like that, they told me its not uncommon people waiting on a bend then launch themselves out in front of the them.
Had to clean some kangaroo off the front and underneath of a few Loco's during my 10 weeks there. Big chunks of bloody fur everywhere on the axles.
pretty messed up indeed.
similar thing happened prob 4 years ago at merrylands train station, the idiot tried to cross the tracks by jumping down from the platforms and yeah, got owned. serves him right for trying to cross. cops & ambo's came in prob 10minutes, trains were terminated and had to get a cab/bus/lift home
Man that's crazy... I even had a dream I died last night, that was bad enough!
lol that bullshiet dude......
apparently i read up that in dreams...an individual actually never dies......
and i kinda agree...ive dreamed of dying...EXPERIENCES....but at the end of it.......you just either wake up or just some how get out of the situation.
anyhow dude......sorry to hear......that wouldve been a big mess......
ive seen a Suicide in Newtown Railway Station... an Emo or Gothic guy hung himself on the frames above the railway lines..... not a good site at all....
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
