does anyone sell an exhaust header flange for rb25 in australia? can find couple in states but trying to source some blank ones locally.
what have people done when making there own manifolds?
thanx
jason
I have a laser cut one to suit RB26.... doesnt help you though.... I got it drawn on CAD, still have the file, just give it to the laser cutting place to be done.
  • 1 month later...
My local exhaust joint took a stock exhaust manifold of mine and sent it away to get a flange laser cut.
Had some time this arvo and finished miging my steam pipe manifold for my turbo charade project.
Just need to finish die grinding it and then get it ceramicoated.
post-12712-1240100609_thumb.jpgpost-12712-1240100639_thumb.jpgpost-12712-1240100671_thumb.jpg
  • 1 month later...
  • 1 month later...
Usually what I do to make up an exhaust flange is to go down to the wreckers, and buy a 2nd hand manifold, draw it up on CAD, and then get it laser cut in 10mm mild steel (sometimes 12). It's easier if someone lends you a manifold to copy, or you already have one.
Sometimes you can just buy the gasket and use that to draw your manifold up in CAD.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
