I have been asked if I would make some more Nismo style wing struts.
I would need at least six payed orders to make it viable to get some more laser cut, welded powder coated etc.
Delivery would be approx 2-3 weeks from the six orders being payed up.
Cost will be $320.00 per set mailed anywhere in Australia.
I have attached some pic's, let me no what you think.
https://www.sau.com.au/forums/topic/258903-r34-nismo-style-wing-struts/
What do I think? As the owner of an R34 Coupe with the genuine adjustable rear spoiler (factory fitted from new together with several other Nismo options) - and with the car stickered very discreetly from the factory to identify Nismo options are fitted, I am very much amused by cars copiously covered with extravagantly huge -look at me - supermarket bought "Nismo" stickers, and especially so if they are running very poor imitation copies of Nismo product - lol.
Why don't you just call them "your style" wing struts?
lol
lol
Well aren't you my shining knight!
I'm only trying to offer a service, if people take it up all well and good, if not no skin of my nose. I have seen alot of people chasing these me included. They are no longer available, and when they were they sold for $750 plus.
As for the Nismo decals, I also have several Nismo options and my cars apearance is totally my own choice what that has to do with this thread is totally beyond me!
If your interested in the group by, good. If not, go back out to the sand pit with the kiddies.
Edited by Wogboy
can you install the wing struts without the plastic covers?
any pics on how to install the wing struts ?
You can install them without the cover as the whole strut is powder coated black.
I do have some fitting instructions that I did a couple of years ago, it's a big file though. If you can PM me your e-mail and I will send them through.
Thanks.
lol
Mate I can stomach spending over 1K per a rim for Nismo LMGT4's but did you ever stop to consider that people may not way to pay over $800 for a product that is clearly not worth that much and the fact that the product is no longer made? I would have snapped these up if I still had my R34. Maybe you should pop down to blockbuster and rent this...
Isn't the idea of this thread, to see who is interested? Oh and by the way yes you are my HERO.
lol
you sir are an absolute fool. The thread title reads... Nismo STYLE struts... because that's what they f*cking are retard! The guy has kindly offered to make some up for people who obviously like them a lot, and at least give people a chance of getting products similar to something that has been discontinued.
f*ck off out of this thread and take your ALTIA kitted 34 somewhere else, cos the kit you sport sure ain't Nismo
Sorry miss read, thought it was that other tool again :blink::P:( :(
Thanks for your support.
Thanks, that's what I thought to.
So do these just slot staright in to the factory wing and bolt onto the boot?
What material do you use for the uprights?
These bolt straight to the factory mounts, unbolt the old and bolt in the new.
They are cut from 5mm aluminium.
Thanks for your interest.
Guest
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
