hi guys, proxies are banned at work and i can't access the skylinesaustralia website, i get this error in firefox
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression
and in IE, i get the page cannot be displayed. ive used a proxy b4 to access sau and it worked fine but i got caught using it and been warned about it lol.
i can access other forums fine (eg: nissansilvia.com)
any recommendations without using proxies.
Cheers
https://www.sau.com.au/forums/topic/258953-issues-browsing-sau-at-work/
IT guys told me that your server & work proxy blocks the way sau is coded or something.
only way i can access it is to go to google.com > skylinesaustralia forums > click on cached
and view from there but you dont get far & you can't post.
  • 1 month later...
I have this same error after upgrading my proxy from squid 2.7 to 3.0. The squid devs reackon the webserver is misconfigured;
They said to me;
"Please notify the webmaster of that site about the issue a well. It is
caused by a HTTP/1.1 misconfiguration at their end that 3.0 does not
cope with well.
http://squidproxy.wordpress.com/2008/04/29...decoding/"
Basically Squid 3.0 talks to webservers as an HTTP/1.0 client, but the webserver sends chunked encoding which is a feature of HTTP/1.1...BUT i couldnt see any options for tweaking chunked encoding in httpd.conf... so i dont see how it can be configured around in apache - i think it more just the way apache works. I'll just use the squid workaround, but i'd say dori34 is probably stuffed, unless PranKeh can figure out the config.
I wonder if it has anything to do with gzip compression... Those who are having problems, are you able to ping the site? What if you use the PDA skin? http://www.skylinesaustralia.com/forums/Is...1&skinid=21
I've run into this problem before at sites with proxy servers and believe it is the way that it handles the code from the website. It seems to have fixed itself with an update that has been pushed out to the firewall appliance we use. To get around it I was using GPass at one stage but that seems to be broken (well it stopped working for me) and then I started using a site called http://www.boomproxy.com This got me around the problem of at least being able view the site and browse. Some of the scripting doesn't seem to work through it though, but good enough to browse, read and reply to topics.
I'll try to find out what was updated on the proxy server side of things to try to work out why this is happening with the website.
OK I've spoken to the company that we deal with for our internet appliances (firewall, proxy etc) that we use.
I asked him about the error that I used to experience and why it now works for me. This is his response:
The website will not be responding correctly to HTTP 1.0 requests, it will be returning some
broken HTTP 1.1 responses. The proxy server in 26.4.7 now sees these broken responses
and removes them. You can also change your browser to use HTTP 1.0, which will mean that
it ignores the broken 1.1 responses altogether, making it work.
So for people who have this problem, it looks like it is how your proxy server deals with the broken HTTP 1.1 requests.
Sometimes it might not be the proxy server at your work end, some ISPs also use a transparent proxy (TPG is one that I know of that does)
I got a couple of pages to load, but the third i tried failed. Its not a compression problem despite what the message says.
Deano,
Are you able to get a list of the broken responses they found?
Christian
Hi Christian,
Ok this is from the proxy server log of a site that I have that still has the problem accessing the website
I'm not a website guru so I hope this helps. This is just trying to get to http://www.skylinesaustralia.com from a machine behind the proxy. IP address is a private internal one so it doesn't matter that you can see it.
Apr 29 19:25:20: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/ HTTP/1.1" status=302(Found) size=310 CACHE MISS
Apr 29 19:25:21: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/forums/index.php? HTTP/1.1" status=301(Moved Permanently) size=407 CACHE MISS
Apr 29 19:25:26: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/forums/home.html HTTP/1.1" status=200(OK) size=4245 CACHE MISS
Nathan
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
