Hi all,
Just wondering what head studs I should be using for my RB30/25 (RB25 head studs im pretty sure)
And what brand, I know ARP is probably the best/most known. . But looking at them on ebay they are about $250-300. . .
I dont really want to pay that much, is there any other brands that I could be looking at..
Also, I have a set of stock RB25 head studs here, but I was told not to use second hand head studs??
Thanks,
Josh
https://www.sau.com.au/forums/topic/259080-what-head-studs/
One factor that makes many engines hard to seal today is the use of aluminum cylinder heads on cast iron blocks. Aluminum heads save weight but expand 1.7 times faster than cast iron when they get hot. The difference in expansion rates creates a lot of motion and scrubbing between the head and block.
You may be able to reuse them with no adverse effects if you make sure the threads are clean and not deformed. However many engines like RB's use "torque-to-yield" (TTY) head bolts that stretch slightly when installed. This provides more even head loading and allows the bolts to hold torque better for improved head gasket sealing.
When the bolts are installed, they're first tightened to a specific torque - then tightened an additional amount that's measured in degrees of rotation. This final twist stretches the bolts to their yield point and creates the elastic clamping force that provides more even loading across the head and gasket.
Because TTY head bolts stretch slightly, some auto makers say they should not be reused when the cylinder head is removed. Reusing TTY bolts will cause them to stretch further, which increases the risk of breakage. A stretched bolt also will not hold the same torque load as before, which may cause a loss of clamping force resulting in head gasket leakage. The best insurance is to replace all TTY bolts when rebuilding and reinstalling a cylinder head with new head bolts. So if your engine uses TTY bolts, replace them. Be sure and torque to the correct setting and in the proper sequence.
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4451971
No worries. . Thanks heeps for the info. .
I read somewhere that you should do them up to the specified torque, then undo them all, then do them up again. . Or something along the lines of that?
yes its a 5 step process torqueing head studs.
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452154
For the last step with head studs, when you tighten it to an angle, is there a way you can do it without buying on of those tools? (can't remember what they are called, the ones that are like a torque wrench but display angles).
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452337
ok. . and which tool is it that i need for the 5th step?
1/2 inch drive angle gauge...its got a 1/2 inch socket on the top for your breaker bar to clip in to and a 1/2 inch drive to go into the hex socket you will need to fit the head bolts. its got a round dial on it with angle graduations marked on it.
ill try and dig up a picture.
edit...here ya go.
http://www.ntxtools.com/Merchant/graphics/...01/otc-4554.gif
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452582
Ahhh angle gauge that's what i was thinking of :laugh:
So no other way to do it without buying an angle gauge ay.....hmmm
EDIT: Actually i just had another look at the engine manual, it says you can tighten it to 93-103Nm for the 5th step....therefore you don't need an angle gauge?
Edited by PM-R33
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452591
my arp head bolts cost $165 for set, aussie dollar was equal to the yankies :)
320 now - ouch
I shudder to think how much my head rebuild would cost now with the dollar variations (ie poncams were under $800, 8.8mm springs were $300, etc)
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4453212
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
