So I pimped my old man's car cos I was embarassed to be seen in it.
Oh snap! Godfather rims baby!. 18x8.5" in the front, 18x9.5" at the back. Hoping to stretch some 215/35/18's in the front and 225/40/18's in the back. I might hit up Option1Garage for some Cum-ho's.
Has anyone had any issues fitting this size on a cef in terms of rubbing and stuffs?
Also just bought a Grace bodykit from Erin @ JDM Garage up here in brissy. Needs a bit of work and some paint before it goes on.
https://www.sau.com.au/forums/topic/259279-rollin-on-vip-godfathers-bitches/
yeah I know... "Rollin on Tweeeens bitches" doesn't quite have the same effect tho.
Well technically I bought it for my dad (hence the auto trans), then I got it back off him after he wrote it off. So I guess its my car now.
when did he write it off, u mean that lil scuff on the front bar back then?
lol
far as i no mite need to mod the rear bar wheel arches a lil if your gonna run a body kit
looking the goods
Edited by Dan_J
some lady back into a 3 lane road while he was comin down it at 70... radiator panel took the brunt of it, and the right fender. bonnet was pushed up. Insurance co wrote it off, I bought it back, fixed it up at Driftline, welded in a new rad panel, replaced all the broken parts, re-engineered and now back on the road.
hey
how you going
looking at the stick out of them, i have rims with similar amount of stickout
the tyres you specified will go fine without guard rolling - speaking from experience here
looks the goods man
ummm its this kit... which is a Grace kit from what I can tell, but some people seem to think its the mythical Autech S2 kit, and other think its a TBO kit.
that looks like phil's old car, but its not, just very similar(unless it had a few more changes nd then was shipped out)
its "works"(insert other letters/numbers here) car now, west side of melb
Edited by Dan_J
  • 5 weeks later...
got some Kumho KU31's stretched onto the wheels last weekend. Bigups to Option1Garage... great guys and prices that make me want to touch myself in inappropriate places.
215/40/18 on 18x8.5 +35
225/40/18 on 18x9.5 +35
Ready to go on the car
rolled the lip on the guards and fitted the wheels up today. realised that my rear's are sporting some gangster toe in's will have to fix soon.
Huge thanks to dave for taking a few hours to roll my guards. Very nice finish.
Car sits about 7cm off the ground... with 3 people in the car the exhaust hangs about 2cm off the ground... gonna have to do some remedial surgery on the mounts this weekends.
Flushhhhhhhhh
Pants tighten everytime you look in the side mirror and just see the edge of the wheel chillin outside the guard.
Flushhh FAIL in the front by about 1.5cm. Didn't realise that the guard would flex so much when rolled. will need to get longer bolts and space it out or buy more Godfathers... MOAR GODFATHERS!!!1!
And finally...
You know you love it. myrewards!
Yer I own the phil/softy mobile now.
I spoke to him today and he thinks its the same car.
tbo kit came from jdm garage yeah phunky?
I inquired about it but couldnt get a straight answer out of him regarding it.
Stock bars with lip for me, no fibreglass to smash off :(
Pm send Dan_J
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
