yeah. last thing you need is a bloke 100000kms away slaging your shit after hes paid good money and the f**ker locks up when its all tensioned down..
shane.. so your countersunk holes are oval? what about when its tightened? wont it centre itself being a taper?
That and relying on someone else to line bore it properly are my my greatest concerns lol
i dont actually use tapered bolts, i use a proper cap headed bolt. And for the 5 8mm bolts on the diff side that u need to tap the block for, i use a special half headed bolt so it leaves enough meat in the plate when its countersunk.
I decided not to use a tapered head bolt as a normal square headed bolt has a greater and more even surface to clamp down with.
  • Replies 82
Sorry Shane, I'm really not trying to rain on your parade but your going through the exact same issues I had to sort out years ago.
Are you using countersunk capscrews to hold the outer perimeter of the cradle to the rails?
Best thing you can do is build a motor with your design, address each and every problem as you get to them (there are still many more to come, trust me), run the motor at at least 1300-1400hp/10,000rpm to test it all, after 12 months or so and possibly several revisions/changes, you may have it sorted out and to a point you'll be able to sell them to the type of customer who can justify going to a full billet cradle in the first place.
Unless its proven in very high hp, high rpm motors your very target market possibly won't want to use it.
Many times over the years, I've been told my ideas won't work or arn't right but I never gave up and I tested everything myself so it was only my money I wasted if it all turned to shyte so keep going and best of luck to you with this and any other of your ideas,
Rob
Rob
Dont worry rob i really do appreciate your pointers as you have been building these things for years and have great results, clearly shows ur a wealth of knowledge.
U prolly didnt see my post just before, but im using a convential cap head bolt, not a tapered bolt. I can see the issues ud have if u used a tapered head bolt though.
Yeh i was going to wait and test it on my own car but its getting some chassis work done atm so it wont be ready to use for sometime, also i'm working with a workshop who have cars available to test on and if testing goes to plan a drag car to test on half way through the year.
I do see issues already like how are we going to overcome differences in thermal expansion (most likely by running non-std clearances), line boring with the 2 different metals and many more, but like u said thats what the testing is there for!
Thanks for the help so far, i really do appreciate it :P
  • 2 months later...
Hi all,
I've had quite a few people after kits. We're currently out of stock until at least the first week of June.
smorcr, I doubt anyone will give you the cad files to have one cut. Being in NZ, why don't you get one from RIPS?
Hi all,
good luck with that 1 hey greg
:P
Hi all,
I should have posted this 2 weeks ago. A couple of minutes after typing the post above, 16 plates arrived from the laser cutter. They will be machined Monday and back in stock. I'll take some video of the CNC process, it's pretty cool to watch if anyone is interested.
HEY rob in in auckland and would like to know more about your kits can you email me a price and what comes in this kit plz send pics to and if theres more than 1 opp then show me my opps and prices EMAIL me [email protected]
Most of the info you're after is on his website, proengines.com.au - have a look and email him.
I've just used a pro-engines plate, the quality is excellent.
with a bit of work the guys at hills motorsports have retained the internal oil pump pickup too.
Good to hear Duncan, was Mark happy with it?
  • 7 months later...
Sorry for digging up an old thread!
I have a Trust Sump extension and was wondering are the proengines/shane/rips etc internal pickups made for the stock sump?
or are they custom made each order to suit?
I know a GTR in UK has modified a proengines pickup with the Trust pickup however i was wondering is there a bolt on option
We can supply them with a semi finished pickup that needs to be cut to length to suit the depth of the sump. It's a fairly simple job but you need someone who can tig weld to weld it together once you have the length right.
yep, mostly because it was complete and spot on :thumbsup: there might be cheaper options for basic cost, but this was a straight fit, no stuffing around option which is exactly what any workshop wants.
no point saving $100 and then having the workshop spend 4-8 hours modifying things to fit at $80-100/hr
We ended up using the standard pickup so it is about 1cm higher than normal - as a result I run a little more oil. We could have extended it as suggested but this is just a roady and it wasn't worth the trouble.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
