Hi All,
Ive had this anoying sqeak for the past week or so only notice it when im going slow and theirs minimal road noise (under say 40km/h). Tonight decided to investigate it a bit more. Ive worked out that when I push down on the Passenger front guard to compress/move suspension it makes the sound.
I removed the wheel and sprayed some inox on the any moving parts i could see to see if somethings just super dry or whatever and then put the wheel back on and had another push and the f**kers still their. :blink:
If i was to remove the coilover and completely remove all the suspension components lube them up and re install will I loose any camber or toe/alignment settings?
Any ideas?
Cheers
https://www.sau.com.au/forums/topic/259313-anoying-sqeak-from-front-left/
i had the same thing. and i know the frustration in trying to find it. but i ended up finding it.
pull the wheel off and undo the bolt at the front of the upper control arm. the is a bush in there with a spring assisted lip seal on it. get some lubex or inox or similar and spary it inside that bush. i poped the spring off and gently lifted the seal up with a small flatblade screwdriver and spayed a heap of Lubex in there.
when you are putting it all back together, put the bolt back in and just nip it up. then lower the car first before doing it up tight.
Yep, QWK32 has it right: I had exactly the same issue from both sides at the front: lubed up all the bushes and it was fine... I'd give that a shot first, and chances are it'll fix the issue.
what am i being carefull for when it springs up will it bash the guard? or just keep my hands clear?
If its just to avoid hand injury ill get cheffstagea over here to do it and not tell him... ive bled many times due to his cars :@!
yeppp cheeerssss
Bang on the money here guys!
Jacked the front on stands. off with the wheel.
Took the bolt out and removed the spings from each seal and pried the seals off. Sprayed some inox inside and then pulled the inserts out of the bush and greased the life out of everyhting. Put it back together and put wheel on dropped car down and snugged the bolt up.
Queit as a mouse =)
Thanks a heap josh!
  • 3 weeks later...
You could just use the whiteline adjustable ones, I've got them in but I'm starting to get the noise on the RHS. I just had a wheel alignment so I'm not going to bother stuffing up my front camber settings just to get rid of a slight squeak.
  • 4 months later...
Just tried to get the MF out. No can do with 17mm ring an two foot lever. Need to get my rattler back.
Incidently when I wanted to search for this thread I typed in "squeak' and got no response. The original post was "sqeak".
Typed that and bingo.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
