Both cost the same money,
Both are inline6 cylinder turbo's.
Heres some fast facts on the fast Ford:
Price: $43,965
Engine: Inline 6cyl dohc, 24valve turbo
Weight: 1732kg's
0-100km's: 6.0 seconds
0-400m: 14.3 seconds at 162km's/hr
Dont have the stats on the R34..
Consider that the R34 you buy for that money will most likely be a '99 model, and not a new car. Which would you buy, and why?
Which car is better? :)
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/
  • Replies 68
i would buy R34. The falcon is too big, heavy, common and not as quick to drive (refering to BFYB 03). I don't need/want 4 doors. and even if i did, i'd pay extra and spend a whole lot mroe time, just to find a GT-T in manual. A similar M.Y. chaser is also another car in mind for 4 doors
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549725
I thought that would stir the hornets nest a little :)
I think they are quite similar cars, the only difference is the fact that the falcon has four doors. I'm sure in the back the skyline has only a bit less leg room.
It's not as outrageous comparison as say, V8 HSV GTS vs R33 GTST.. (differen class, different ages..)
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549736
Originally posted by pentae
Rezz: A 2 Door Sports car that is slower than a shitbox falcon?
Ok fine, the Falcon might be faster(?), but why compare the two?
A better comparison would be a JZS161 Aristo and a Falcon XR6T?
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549757
Now Now guys.. let's not get too carried away. I love my Nissans just as much as you do.
But if you want a Nissan family car the GTT & GTST are it. If you want a Nissan sports car you get a 200sx. If you want a racing performance machine you get a GTR.
The GTT is a Japanese family car with a turbo 6 engine, just as the XR6T's are.
It seems everyone has a different definition of sports car, and family car.
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549763
i think u mean that the 4 door skylines are family cars if that. dont forget skylines hav also been about performance, unlike the commos and falcon who hav had performace forced on them. i agree there are levels of sports cars but not to the point were a skyline is a family car and a 200sx is a sports car. some people would say that porsche and ferrari make REAL sports cars(compared to japs), some would not
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549785
Rezz: Aristo's arent exactly common like the R34's are.
R34`s aren`t exactly Taxi`s...:)
Seriously, the Ford weighs nigh on 1800kgs, they just keep getting heavier and heavier, when logic (and our son of rajab Colin Chapman) say otherwise, and Ford and Holden are actually spearheading a totally new class of automobile... the "500kw House"...:(
All good in my book, just I think they (Forb and Holdem) are in a class of their own. Incomparable to anything else but themselves...:uh-huh:
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549819
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
