Hi,
I have been searching the forums for info involving relocation of peoples air filters, and it appears there has not been alot of discussion about this.
I have an R32 RB20DET and have been researching the construction of a cold air box and some cold air intake, when I realised it would be easier and possibly more effective to just relocate the air filter so that it lives in front of the front passenger tyre behind the spoiler.
I just want to see whats peoples opinions and past experiences are with this in regards to implementation, effectiveness, legalities and other potential problems such as water, dirt etc.
From what I can see, I may have to cut a hole in my car if I want to use a 3" pipe, as I think a 2" may be restrictive. Any comments on this? If I can get away with a 2", then there are factory holes which can be used.
I have a dry Apexi filter, so I dont have to worry about water washing off the filters oil, but what about water vapour being sucked in to the engine?
I have seen this done for drift cars, but they are hardly street legal and wouldn't have to worry about going through puddles etc...
If this has been covered before, feel free to send me the linky :)
Cheers!
https://www.sau.com.au/forums/topic/259722-relocation-of-pod-filter/
Best place to relocate the pod filter to is the Shed.
in it's place put the stock air box.
if you must keep it, people have put in in the stock intercooler spot before.
then you have to put a shield to stop all the stones and water from getting to it, so some sort of shield.
also, people have found that air with that much force on it has caused problems with the afm.
also remember that cutting a bigger whole there in the chassis is Illegal.
I have run this setup on a few cars of mine.
The upside is you will get a noticeable increase in power.
Downside is you will have to clean the filter regularly. If you mount it really low (level with the base of the front bar) then it will suck up water when you go through a puddle.
If you mount it flush with the metal on the other side of the panel, then you will not have any issues. It also pays to make up a cheap deflector out of Alloy rail. Shaped like a U on it's side, you can mount the deflector around the filter to stop any water from splashing up. It will also help to direct air into the filter. This requires a little bit of thought in it's setup and is not necessary but a good idea.
+1 on the standard air box with a good panel filter.
But as for illegal, this is not so. It's not the chassis and it's not structural. There is already a hole there and it is not illegal to enlarge it.
Indeed there is a hole, and enlarging it would actually work. I would only need a little bit more room to allow both the intercooler and the intake pipe to fit through..
I was planning to mount it as high as possible, and I still have the plastic guard attached to stop any major splashes. If I do go down this path, I would probably make the U guard as well for added protection.
Also, what tubing have you used? Did you use proper piping or the same sort of rubber tubing already used?
I did this once on my old r33 back in the day with some flex pipe; did in fact make a great difference to response
BUT
Gave the pipe to my friend who had a vl; he relocated his pod to the front and after driving through a puddle, his engine seized
anyways just thought id share cos id say ratio of benefits to risk = not worth it
HAHA His engine seized due to water going into the intake? I find that hard to believe. Would maybe bend a rod but not seize.
A nice legal way to do is this if youre that set on a pod filter:
Cut big hole in bottom of airbox - 3"
Cut big hole under airbox into chassis matching airbox - 3"
Get some 80mm or 3 inch flexible rubber tube connect it to the afm using pod adaptor
Run the pipe from the afm through the hole to behind the front bar
Mount pod filter with stone/water guards
Modify the top section of the airbox to suit
Close airbox
You cant see the tube from the afm going under the airbox - its looks standard.
Did this on a mates car and fooled cops every time.
It is in Vic - if you own a Airbag equipped model. Not sure about other states
Non Airbag you can do what you like :banana:
Its classed as structure as its 'any material forward of the firewall' or something to that effect.
Hence people here cop Engineers defects for I/C installs not using the factory pipe holes (if they have an airbag)
It's fairly annoying, but then i can see a reason albeit it minimal
Hey,
Heres a link to what i did on my 32. Works well and have had no issues with water going up there or rocks etc. I have a custom airbox over the top of it all.
As for legality, i dont know about perth, but i read awhile back that in nsw its illegal unless you reinforce around the hole you cut to retain structural integrity. Also think it needs to be engineered. Have a look on your local motor registry website.
Link http://www.skylinesaustralia.com/forums/in...t&p=4433034
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
