You've done a compression test and found a little drop in cylinder no1, so if it was me, thats where i would be looking.
Do a leak down test, theres a good chance no1 will fail the test which more than likely means headgasket.
All the other ideas are good, but when you've got a questionable compression test i would be looking there first.
but did they pressure test it hot? I know of a few now that did not show up under initial testing. car was puit back together and it happend again. crack was only opening up at temp. new head and the problem went away. it can sometimes be hard to diagnose. pourus block is less likely in my experience.
I was told it was x-ray'd for cracks.
An x-ray will show up a crack even if it's not hot right?
yeah you would hope so. but my advice would be get it leak tested HOT. people have been fooled before with 26 heads. the cracks is not always easy to find.
Yes, i've checked the water/oil mixture tap, flux capacitor and fusion reactor and they're all fine.
Any other ideas?
No sorry. You have checked everything.. you should pobly pull the engine out and get it fully checked.
could it be the block is cracked between where the head bolt goes into it and the water gallery on the outside of the bore.
99% of the time it's the cylinder 5 or 4 one EX side). The crack is usually very small, but grows. If you pull the head off you may not even see it as it starts sub-surface. Skim the block and you'll see it clear as days.
You get trace oil accumulating in your radiator, especially in your overflow? You empty it, it comes back?
The crack is small, but as the oil pressure is greater than the water pressure, it forces the oil through the crack into your water system. Over time, the crack will get bigger, and more will start on other head bolt / gallery places. The harder you drive, the faster it does it.
That is exactly what mine has done in the past
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
