Hey Guys,
Just picked up the newspaper today and on page 6, let's just say it entertained me. . .
I wanted too know what everyone thought about the new sign. .
I have witnessed many false judgments from police that a hoon was taken place. Would it not be a personal insult too mark you car with such a "media idea" such as a banner "Hoon"?
Just thought it would be a good topic too discuss.
More info on the banner :http://www.thewest.com.au/default.aspx?MenuID=77&ContentID=128494
https://www.sau.com.au/forums/topic/259882-hoon/
  • Replies 58
Posted Images
Ate they going to tattoo "murderer" on a murderer's forehead?
LoL So True.
Might as well Tag more serious crimes such as "RAPIST" or "CHILD MOLESTOR" on the offenders car, so the public can be aware.
"To insure Justice" Wow they make it sound so noble Bahah
https://www.sau.com.au/forums/topic/259882-hoon/#findComment-4461677
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
