v35 paul - did you do an ECU reset when you installed it? maybe hence why the stock one is trying to "learn"
and on another note-----
is there any difference between the CF Z-Tube and the stock Z tube item? (besides looks of course) im mainly talking about quality etc. is the CF real carbon fibre or just an overlay... etc.
-mark
Edited by BLISTC
  • Replies 94
Posted Images
-mark
Don't know how to reset the ECU.
The CF Z-Tube would have less heat soak then the stock Z tube and and any metal tube would have the more heat soak over time.
  • 3 weeks later...
So this morning i woke up and UPS man was at the door with a parcel.
Finally the Carbon Fiber Z Tube i had ordered 1 1/2 weeks ago had arrived. I ended up ordering it from www.thezstore.com and it was $195 AUD delivered at the time the exchange rate was around 75c
The Z Store's tube is actually sourced from www.evo-r.net but they are cheaper. Evo-R.net are the manufacturers of this Z Tube. It is made from real CF and it is really well made as well. I peeled off the EVO-R sticker which came off pretty easy and left no residue. I like it to look clean, and with under bonnet temps this sticker will just fall off over time anyway.......
I went to work and got home around 11pm. I couldnt wait and seeing how easy the DIY was i decided to attempt this install.
It was a fairly simple and straight forward install. 15min later and i was done!
Finished the installation...... dammit i need to clean my engine bay!
and here is the picture of the part it replaces.......
see it is just not all for looks, these things actually increase the air flow, due to the stock part having so many resonators for noise etc. and hence provide a very minimal increase in power (and they make lots of induction noise now too WOO!)
I really like doing DIY...... it feels very rewarding once the job is done (especially for a n00b like me) :)
-mark
Edited by BLISTC
-mark
EXCELLENT write up i needed this information. How does it sound. Are you going to get the rest of the intake , i.e. spacer and filter?
How is the quality are you happy with it ?
I really like doing DIY...... it feels very rewarding once the job is done (especially for a n00b like me) :laugh:
-mark
VERY NICE~~~
let's make a GROUP BUY!!! who's interested?! :banana:
the induction note is definitely louder as all the restrictive parts have been removed. you really only hear it in the upper rev ranges when you give it a bootfull....
as far as power goes, i really dont know cant tell. i already have a K&N Drop In Filter, i dont think i will spend the money on the popcharger etc. as when i get the supercharger it is pointless anyway
as far as quality goes, its pretty damn clean and nice. very well made.
the only gripe i have, is that the emissions tube is a bit further down and you have to like stretch the tube a bit further down, than where the stock item is placed. also you really need to stretch the accordian rubber parts in order to get a good fit, as IMO it doesn't line up as good as say the factory z tube.
-mark
Edited by BLISTC
Looks like you took out the resonator. Underneath the airbox correct ? Doesn't do too much, just quietens things down in terms of induction/engine noise.
I had mine blocked off but thought it hampered response, so unblocked it. I have no idea why, but maybe because the factory airbox design/flow relies on having the resonator there *shrugs*.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
