Disgusted - Why people have to be rude?
Guest Daihatsu_Dude
Its pretty simple really.. If you can say that you like a car, i should be able to say that i dont like it.[/quote:61ba99d322]
Okay but how would you feel if someone said that your car was a piece of shit on wheels????? [i:61ba99d322]Would you feel offended???[/i:61ba99d322]
Guest Daihatsu_Dude
"]Diahorrea_Dude, please shut up our carefactors are wandering into unchartered territory... :evil:[/quote:a935b60b02]
Ryan you little 15 year old Mr Know it all, Have you got anything nice to say??? Dont get me started on you......dont want me running your PUSH BIKE over do you?
Okay but how would you feel if someone said that your car was a piece of shit on wheels????? [i:216fdc4299]Would you feel offended???[/i:216fdc4299][/quote:216fdc4299]
Remember that saying- Sticks and stones....
You gotta give it to Ryan though. He's a funny c**t.
Guest [ryan]
Its pretty simple really.. If you can say that you like a car, i should be able to say that i dont like it.[/quote:6e16e260ff]
Okay but how would you feel if someone said that your car was a piece of shit on wheels????? [i:6e16e260ff]Would you feel offended???[/i:6e16e260ff][/quote:6e16e260ff]
Hey Diahorrea_Dude, your car is a piece of shit on wheels!!!!
Guest unfamilia
daihatsu - well, i probably wouldnt take it as a compliment. But my car certainly has never attracted any comments like that - most comments are 'shit i just got wasted by a hatchback' or similar.
thats my point exactly - if you buy a car with airbrushing and its all fully sik to the max, you're gonna get comments like that- deal with it.
as christian said, he doesnt want this shit on his forums, so im all done.
[email protected] if you wanna argue any more, im up for it - because its quite amusing.
(the car and the argument)
  • 2 years later...
