yeah for sure. i know a few local guys up there too. so ill get them to show everyone the car scene.
just beware of the main street, last time i stayed there, the main street is one way. so it was full of people doing lap after lap hindley st style. but think 10x smaller and instead of clubs, its a single pub. and all u see is commo, commo, commo, falcon, commo, magna, commo lol.
  • Replies 499
Posted Images
Hey all
Just a FYI in regards with entry forms and club displays.
It is preferred by organisers of shows that all club entries are sent together rather than one by one. This obviously makes it a lot easier on them and they then know how many are in the display itself (unless there is a late entry or two which i can always call them up and let them know of the details of the people entering late).
If you send in your entry by itself, most organisers will see that as a individual entry, not a club entry (unless i have spoken/emailed them in regards with any late entries or change of enteries etc). I can only do my set up plan with the people i know that are entering via who has given me there entry forms/entry money, and its a massive pain in the butt when you get people that choose to enter on the day, and not actually give me any warning that they are choosing to enter or not (in the sense of i can do up a back up plan with their car on it).
This is not having a go at anyone, just more of a FYI that if you are gonna enter, please let me know, (which nearly everyone does anyway), or if you have entered, and then change your mind (say you entered as a individual and then decide you would like to be part of the club display) please let me know no later than the week before the show itself. this gives me time to sort out my plan or make the necessary changes and get in contact with the show organisers aswell.
Car Shows can be stressful enough, especially when i have my own car + need to sort out everyone else's too!!!!!!! So all i ask is that you can co operate and let me know if you have sent in your form individually and change your mind as you want to be part of the club display cause if you ask me on the day without any prior warning, the chances of it happening will probably be minimal as i wont have the time to drop everything to sort it out :)
It will just make my life alot easier and ill appreciate it heaps :3some:
Thanks guys
:iluvff:
Hey Cara
Lynette Williams's (organizer of the show) husband used to work for my father-in-law when he was a boss at the Wallaroo council.
I had a chat to her and told her I'd only bring the bike up if the weather was good so she's made an exception for a last minute entry.
Let me know if this stuffs you around.
Cheers
Hey Pete
thats ok cause you might be put in a different area to what the club is being put in. i know last year they had it marked with "Holdens" "Fords" "Other Make/Model" etc so id say that the bikes would have their own area :)
Edited by MissR34
+1
Group entries are just that: applications entered as a group for a club display.
On that note, Lex, if you're reading this, I made Cara aware that you've put your form in to enter the show. However, I am not aware if you informing me of this was a simple courtesy to let Cara know you're in the show individually, or if you intended to be in the club display also. I took it simply as courtesy to let Cara know you'd be in attendance. If you are intending to be part of the club display, can you let Cara (or myself) know so the proper preparations can be made sooner rather than later. :)
This of course applies to everyone else, as per Cara's post above. If you want to be in the club display and your form did not go to Cara for the group entry, please advise Cara asap.
:iluvff:
i was intended to be in the club display also if thats still ok
Thanks for letting us know.
:ninja:
Cara, hope 2 stags now help with the club display ... plus don't forget I now have some serious doof-doof :laugh:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
