  • Replies 70
i wuld be in if its at dromana.... you could organise a cruise then at have it end at a central meet point then who ever wants to go to coburg can and who ever wants to go to dromana can as it seems there are a few people that want dromana and a few that want coburg.. just my opinion.
I think vic street scene have a cruise to coburg on the 25th (cant remember off top of my head) to see the movie for those who cant make this one.
You dont remember when it is but you put your namr down for it, i do the same.
It is on the 25th, looks like its going to be a big one, with any luck i will remember it.
Edited by W0rp3D
yeah whats happening with this? Central meet point then cruise to coburg/dromana?
Teaming up with VicStreetScene then heading to Coburg sounds like defect city and bound to be some hooligans rippin it up upon entry, exit, sitting there whatever.
if this is organized properly wth dates/times/decent cruise involved then i'd be down for it
anyone got any clues?
If anyone isn't happy about the location/date/whatever of this cruise, then I've got another one organised which you can come to.
We've got 3 SAU members confirmed already.
http://southeastimports.proboards.com/inde...y&thread=28
*looks at his copy on dvd*
finacial crisis, moneys tight these days
LOL naughty naughty, however i dont think my skyline would make it into the lounge room to watch a dvd on tv...hey freezing ya ass off and the drive in is where its at....
how good is your copy tho???? hahahah :thumbsup:
how good is your copy tho???? hahahah :D
+1
Cam or dvd?
You guys should come to this one!
All the cool SAU members will be there :D Kris, Chad, AP, Jamie.. and me of course :bunny: (okay, that probably put you off, but come!)
um, sounds is like every before cinema movie. picture is a little off, nothing dramatic, just add one subwoofer, and your set.
scanned through it to check the quality, didnt see anyone stand up during this one, oh yeah it is the new one too
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
