  • Replies 70
i wuld be in if its at dromana.... you could organise a cruise then at have it end at a central meet point then who ever wants to go to coburg can and who ever wants to go to dromana can as it seems there are a few people that want dromana and a few that want coburg.. just my opinion.
I think vic street scene have a cruise to coburg on the 25th (cant remember off top of my head) to see the movie for those who cant make this one.
You dont remember when it is but you put your namr down for it, i do the same.
It is on the 25th, looks like its going to be a big one, with any luck i will remember it.
Edited by W0rp3D
yeah whats happening with this? Central meet point then cruise to coburg/dromana?
Teaming up with VicStreetScene then heading to Coburg sounds like defect city and bound to be some hooligans rippin it up upon entry, exit, sitting there whatever.
if this is organized properly wth dates/times/decent cruise involved then i'd be down for it
anyone got any clues?
If anyone isn't happy about the location/date/whatever of this cruise, then I've got another one organised which you can come to.
We've got 3 SAU members confirmed already.
http://southeastimports.proboards.com/inde...y&thread=28
*looks at his copy on dvd*
finacial crisis, moneys tight these days
LOL naughty naughty, however i dont think my skyline would make it into the lounge room to watch a dvd on tv...hey freezing ya ass off and the drive in is where its at....
how good is your copy tho???? hahahah :thumbsup:
how good is your copy tho???? hahahah :D
+1
Cam or dvd?
You guys should come to this one!
All the cool SAU members will be there :D Kris, Chad, AP, Jamie.. and me of course :bunny: (okay, that probably put you off, but come!)
um, sounds is like every before cinema movie. picture is a little off, nothing dramatic, just add one subwoofer, and your set.
scanned through it to check the quality, didnt see anyone stand up during this one, oh yeah it is the new one too
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
