More Good news!
Great Aron! So R34Liner is IN :cool:
mxfly will update the list in his OP as this thread gets longer!
In 20 days, there'll be a complete programme for all to see!
In essence so far, mxfly's idea has caught on! > This idea grabbed the attention of Jason at High Performance Imports who we are sticking by with loyalty - Thank You Jason > Another notable magazine became interested > a Japanese martial art organisation became interested > some prizes have trickled in through kind sponsors > and there's more...
  • Replies 589
Just a thought,
but wouldn't it be better keeping it as traditional japanese models. This is a celebration cruise. If you want pictures of your cars with models go to autosalon.
This is a one off. It should be different
I'm not saying don't have them
I just think it would be more appropriate to only have the traditional japanese models
in the end though its up to Terry and Eugene
Edited by Black Widow
Good news!
Bakes is IN :/ . Be good to see you again after Singleton! Is Ian coming with you?
Alan is IN :) . I was wondering last week Alan whether or not my local area commander would be good enough, or whether I need to contact the nearest Police Stn to Mt Wilson + Richmond?
Regards, Terry
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
