So thought I'd just start a post on my build for my r34 GTT. Current mods that have been done, Are about to get done and planning. So my cars a R34 GTT, Auto Gearbox and will be staying auto. Current mods are as listed.
Hybrid FMI
Apexi AVCR boost controller
Kakimoto 3"exhaust system with hi flow cat from turbo
HKS Fuel Pump
Turbosmart Fuel Regulator
Apexi intake
Nistune VG30 Chip
standard turbo on 13psi
standard shocks with low kingsprings (will be changing)
slotted rotters all round with red stuff pads so i can stop :(
As of April my build will begin and Im aiming to achieve 300rwkw's on standard internals (with adjustments to the head gasket)
gt35r on high mount manifold
44mm Wastegate
Greddy plenum 80mm Throttle Body
800cc injectors on custom Fuel Rail
Cams (being sourced by mechanic)
Gearbox rebuild with MV Body (possibley changing gearbox, so any info there will help)
Now There the basics on whats happening to the engine. Im looking for around 300rwkw's a responsive drive and plenty of tourqe. Work with the cams will be assential as we want the car coming on boost as early as possible. If theres anything I have forgotten to add that I will require please list.
Engine management? Power FC?
Also a good engineer to mod plate all that stuff especially the high mount turbo.
Nah using a nistune vg30 chip. Will look at upgrading it if it becomes too much for what im using. But Nistunes from my knowledge have handled up to 500hp as to date.
Did you sought out that brake problem i remember reading a post about you had terrible luck with it.
Good to see your on the rise mate..
haha cheers,
Yeh i soughted the break problem out, it took 4 new discs and a set of red stuff brake pads front and back to fix it.
Mind you the problems were.
Discs wernt machined properly then they didnt bolt the brake caliper up and it came off the second time. Then I got the discs machined and they machined them way way too far, then the rotors warped because of it, iw ent through 3 sets of brake pads front and back and now i need a whole new set of wheel studs because one of the companies I will not name put wheel nuts on that were too small and destroyed 2 wheel studs on both sides of the rear. Havent gotten the new wheel studs yet but the brakes are soughted now thank god.
Its an important lesson that most people should learn from. Dont get brakes done at tyre places enless your 120% sure they know what there doing or lese it wil cost your your arm and leg. And possibley alot more.
If your looking at upgrading brakes go to Brakes Plus at Capalaba, great bunch of blokes and trust when I say, from personal experiance I know that they know what there doing.
So my turbo this morning has begun to give some terrible signs of shaft play. So in the mean time looks like i will be getting a small bolt on for the next couple of months or highflow so i can get from point a to b. Shit always breaks at the worst time... lol
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
