So thought I'd just start a post on my build for my r34 GTT. Current mods that have been done, Are about to get done and planning. So my cars a R34 GTT, Auto Gearbox and will be staying auto. Current mods are as listed.
Hybrid FMI
Apexi AVCR boost controller
Kakimoto 3"exhaust system with hi flow cat from turbo
HKS Fuel Pump
Turbosmart Fuel Regulator
Apexi intake
Nistune VG30 Chip
standard turbo on 13psi
standard shocks with low kingsprings (will be changing)
slotted rotters all round with red stuff pads so i can stop :(
As of April my build will begin and Im aiming to achieve 300rwkw's on standard internals (with adjustments to the head gasket)
gt35r on high mount manifold
44mm Wastegate
Greddy plenum 80mm Throttle Body
800cc injectors on custom Fuel Rail
Cams (being sourced by mechanic)
Gearbox rebuild with MV Body (possibley changing gearbox, so any info there will help)
Now There the basics on whats happening to the engine. Im looking for around 300rwkw's a responsive drive and plenty of tourqe. Work with the cams will be assential as we want the car coming on boost as early as possible. If theres anything I have forgotten to add that I will require please list.
Engine management? Power FC?
Also a good engineer to mod plate all that stuff especially the high mount turbo.
Nah using a nistune vg30 chip. Will look at upgrading it if it becomes too much for what im using. But Nistunes from my knowledge have handled up to 500hp as to date.
Did you sought out that brake problem i remember reading a post about you had terrible luck with it.
Good to see your on the rise mate..
haha cheers,
Yeh i soughted the break problem out, it took 4 new discs and a set of red stuff brake pads front and back to fix it.
Mind you the problems were.
Discs wernt machined properly then they didnt bolt the brake caliper up and it came off the second time. Then I got the discs machined and they machined them way way too far, then the rotors warped because of it, iw ent through 3 sets of brake pads front and back and now i need a whole new set of wheel studs because one of the companies I will not name put wheel nuts on that were too small and destroyed 2 wheel studs on both sides of the rear. Havent gotten the new wheel studs yet but the brakes are soughted now thank god.
Its an important lesson that most people should learn from. Dont get brakes done at tyre places enless your 120% sure they know what there doing or lese it wil cost your your arm and leg. And possibley alot more.
If your looking at upgrading brakes go to Brakes Plus at Capalaba, great bunch of blokes and trust when I say, from personal experiance I know that they know what there doing.
So my turbo this morning has begun to give some terrible signs of shaft play. So in the mean time looks like i will be getting a small bolt on for the next couple of months or highflow so i can get from point a to b. Shit always breaks at the worst time... lol
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
