I got my car tuned a few months ago with a haltech intercepter and the temp that day was around 40deg. The car was running fine untill a week ago. Now when you rev a gear out it starts to pull then it has no power, It feels like it just cuts off. I was wondering if because now the days are around 25deg would the air be colder/denser and it's leaning the mixture up causing this problem? I have also noticed that the exhaust out the back is hotter than i remember.
Thank You
no. your fuel pump is no good. or its supply. stick a guage on it and take it for a hit. deffinatly nothing to do with the tune..
mine was done in similar heat. no drammas at all in freezing gouburn
But it's a new pump. And sometimes it will run fine and other times it will play up. i usually find it will play up in 3rd gear.
Could just be over boosting abit in the cooler air and hitting the boost limit .... have you noticed the gauge when driving being a tad higher ?
If you have access to the boost controller / bleed valve etc , try turning it down abit to see if it help.
Gary
Edited by Fastrotor
Gary
I have a EBC and it isn't spiking. I holds boost perfectly
But do you know what the cut is set at in the haltech ? perhaps it was set too close to the mark, and the difference isnt noticable to you on the gauge ? Can't hurt to try turning it down a couple of pound just for a test, if you've run out of other things to try that is.
Gary
Gary
It will even play up on 6psi
How are you testing the EGT? Any chance you have a leaky blow off valve or some other intake leak forming?
I replaced the fuel filter a few months ago and the compression is fine. I went back to the workshop that tuned my car and as usuall they were useless and rude. I decided to drop the base timing back alot and now the car doesn't play up.... it idles really low now but i will adjust that soon.
ok i have set the base timing to 15deg with the TPS cable off. I noticed that the timing jumped up a fair bit when i pluged the cable back in but i guess that is pretty normal. But driving it after that it still feels like the power cuts as you rev out the gears. The only other thing that im wondering is i have heatrange 7 spark plugs in there and the std coils. Now i dont know much about exactly how the different heat ranges affect different things. I know that when its cold it runs like a dog thats fine but should i go back to heatrange 6 plugs till i get splitfire coils? Or could i just be barking up the wrong tree?
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
